Tinbasherdan
Bodger in chief
- Bolton, England
Anyone made their own? Need some for the landy and had a wild thought I could have a crack at my own. I’m sure it probably not feasible but I can try!
Unless they're charge air hoses (and even then, if it's got a VVT, gains are usually on the scale of rounding errors) then they're no better than the cheaper OEM hoses - unless you need them to be 'vibrant' colours...
I want my hoses to be black, not bright blue
That's my biggest problem with these things - I want my hoses to be black, not bright blue. I've had to put a red one on the Audi because it's a tricky one to get for the early engine, and I'm glad it's getting dirty and will soon be almost black. I did read that there are some available in black, but I don't know who picked bright blue as the best colour.
Im not entirely sure if im honest! I don’t think a 3D printed one would stand up though, as the hoses require curing.Are you thinking of 3D printing a former Dan?
Iv conceded and bought some alu pipes and some bends, it’s for the Cummins so no off the shelf stuff available at all@8ob suggested to me ages ago when doing non standard layouts to do the bends and anything weird in either stainless or Ali, then you can use standard off the shelf items and they'll last forever.
I've got gone that way with the 6x6. I've transplanted a GEMs 4.6V8 out of a P38 in it (was originally a Stage 1 so had a 3.5 so it makes sense). The P38 uses a plastic pig heart for the thermostat and has a quite high temperature setting (99C I think). So I've used some Defender V8 hoses and a custom ali T piece to make it work. But it means should a hose go somewhere silly I should be able to use something off the shelf to get me going again.
And installed
Way less faff I think doing it this route than making a silicon hose. Admittedly I've been trying to keep things fairly factory (well factory parts) so I know where I can get replacements in the future.
The bottom hose bends were a standard V8 top and bottom hose cut up but at a pinch any hose with slight bends and a 35mm bore would do.
