Alan Reynolds
Hi, this is my first post in the Tig Dept. I rescued a plasma cutter and a tig welder. Both are probably quite old.
I have cleaned up the plasma cutter inside and out. I turned it on and it didn’t go bang and a very quickly tap of the trigger produced a click. So it’s alive at least.
I’ve also cleaned up the tig, inside and out.
Now, various leads have just been cut through for some reason. One of the two leads going to the foot pedal has been severed both the leads appear to be the same, as the plugs are identical.
My questions if you can help, are can it do arc and tig welding. Looking at the symbols on the front, it can.
Second question is about the gas connector on the front. The pipe has been cut off on the tig torch dines connector end. The pipe that comes out of the machine has the normal gas connector but also a T piece outlet. I know one would connect to the gas line on the dines connector. But what is the other outlet on the t piece for?
Last question is , if I turn it on with out a gas supply, could I at least get a strike and confirm it works.
Sorry about all the newbie questions I’ll be very grateful for any help
The pictures will hopefully shed some light on what I’m asking.
