hotponyshoes
- Somerset. Uk
I'm trying to plug several devices into a generator.
Generator has a 20a breaker.
I've made up a box with 2 sockets, one socket is monitored by a current sensing relay. The relay controls a contactor which supplies power to the 2nd socket.
This works fine, 16a of load is available on the 2nd socket. If a load of more than 4a is detected on the first socket the 2nd socket cuts out. So (not tested it yet!) the generator should never see more than 16a of load and never trip out.
I'm expecting this to work as I want. All the devices I will plug into the 2nd socket are basic things like an electric hotplate. If power is removed it just comes back on when power is restored.
But, I'm thinking of improvements.
For example, I have a portable induction hob,
If power is removed from this I need to use the dial on the hob to turn it off and back on again. It won't just come back on as it was when power is lost.
I'm wondering if, rather than disconnect the 2nd socket completely I can just limit the power draw to 4a somehow?
And, if it is safe (for the equipment) to do that?
I'm also wondering about some method of monitoring the load on both sockets and only disconnect load as required?
Stuff like the hotplate has a simple on/off thermostat, so it's drawing 13a until it gets to temperature then nothing. Then turning itself on/off as required.
I am thinking of a box with 6 sockets that I could somehow arrange in order of priority,
Ie, stuff that always needs power (card machine) as #1,
hand-wash station that only needs power when you turn the water on as #2
Induction hob that needs power but could maybe be current limited at times as #3
Hotplate that can be completely turned off on #4 and so on..
Any bright ideas ?
Any bright ideas ?
