I do indeed but time not on my hands. I have just bought a screw cone. Also ordered a pair of heavier duty plummers blocks and a hefty 5 step taper lock pulley. Overkill but matches what I have on the motor.Maybe fizzy has a taper turning attachment?
Are you not gearing the motor down Vince? Would have thought a 10 to 1 would be minimum, and then an inverter speed control?I do indeed but time not on my hands. I have just bought a screw cone. Also ordered a pair of heavier duty plummers blocks and a hefty 5 step taper lock pulley. Overkill but matches what I have on the motor.
Just hope the motor works. Haven't tested it.
The angle available on a TTA, also, is unlikely to be sufficient. I had to resort to some elaborate bodger getting my Boxford TTA to a sufficient angle to do the job.Maybe fizzy has a taper turning attachment?
Yes i will use machine a shoulder and some collers.You need a bearing capable of taking large thrust loads.
Also the shaft will just slide and get all galled up on the grub screws if you try to use that setup. At least machine a shoulder on the shaft as a mechanical stop.
The people supplying the screw suggest 400 to 500rpn. They just run off pulleys so 3:1 should be ok. I can always modify if needed.Are you not gearing the motor down Vince? Would have thought a 10 to 1 would be minimum, and then an inverter speed control?
Glad I just bought one now.The angle available on a TTA, also, is unlikely to be sufficient. I had to resort to some elaborate bodger getting my Boxford TTA to a sufficient angle to do the job.
Dimple the shaft for the screws deeper than you would normally.Yes i will use machine a shoulder and some collers.
Bearings are heavier duty than the people who supply the kit use.
i would use one bearing and one car bearing as it wouldnt be affected by the loading as you push the log onto it or its side loadingsI do indeed but time not on my hands. I have just bought a screw cone. Also ordered a pair of heavier duty plummers blocks and a hefty 5 step taper lock pulley. Overkill but matches what I have on the motor.
Good vids (for a change @gaz1 ). So no need for sillyness, just some HD bearings and a shoulder and collar to keep everything where you want them, the motor will have a switc?, NO, on the floor so if you get dragged in and start splitting it will at least stop - perhaps a reverse switch might be good, just in case?the cone type can fail and pull the log well over into the pillow blocks
note the splitter underneath
now because im using a 4x2 i can also build a wider splitter as it screws down the log because its wider at the rear it aid in splitting the log
it also wouldnt bother the front bearing as its being screwed over it unlike the other machines
Gazthe cone type can fail and pull the log well over into the pillow blocks
Yes I will actually fit a reversing switch and an emergency stop. Not my usual lash upGood vids (for a change @gaz1 ). So no need for sillyness, just some HD bearings and a shoulder and collar to keep everything where you want them, the motor will have a switc?, NO, on the floor so if you get dragged in and start splitting it will at least stop - perhaps a reverse switch might be good, just in case?
Top vid is “how not to use a cone splitter”. No wonder he had problems.the cone type can fail and pull the log well over into the pillow blocks
Depends a lot on the type of wood - I used to run mine on a Super Dexta, 40hp-ish, and some of the uglies (elm, knotty softwoods) I put through it did labour the engine a bit. Nice, straight ash, oak or chestnut a different story.I had a quick look at one of the videos. He mentioned having a 5ph single phase motor, not that common in the UK. Do you reckon he'd need that much power?
I’ve got some emergency stop stations (telemcanique) that I picked up - quite old (they’ve not been telemcanique for years, they were rebranded by Schneider) but brand new in box and never used, if you want one I’ll Chuck it in post for you.Yes I will actually fit a reversing switch and an emergency stop. Not my usual lash up![]()
