I suppose it does save a good 12 pence using the female couplers![]()
That's introducing galvanic corrosion into the mix also
It's only the brakes - what's the worst can happen?
Oh wait....
Pretty sure i've seen male into female joins from the factory.
Can't remember where at the moment, might come to me later.....
Yes you may be right - but what are you actually suggesting - not joining the pipes?
Even if you replace a whole brake pipe - from manufacturers joins - you still gonna get dissimilar metals next to each other.
Even if you use a female joiner with two male ends into it - you still gonna get dissimilar metals next to each other.
The reason people do it is - they put a single wall female flare on the harder steel pipe for the join and a bubble flare on the softer cooper replacement.
Double flaring old steel pipe and you get problems - the steel fractures and splits.
Single female flaring them is "bodgy" - but as an MOT tester - as long as does not leak and don't look twisted and it is well supported - its a pass mate...
Does that mean they will fail cars on their first test that come out of the factory made that way??Also getting dissimilar metals at brake lines to calipers and other components.
I haven't had problems double flaring steel pipe before but fair enough.
As noted by me and one other person on here so far, unfortunately in NI the testers will fail a car with a female flare on a brake line.
Has to be the double male coupling. Works for me, have a box of them and wouldn't use female flares as I personally see zero advantage and see it as a weak joint depending on a single wall flare to not split or work harden over time.
Nothing else to add to this - just passing on info for what is required in NI.
I was going toIf you want to make a really nice looking job of it, as per Joepro's above, the pipe straightener really is essential.
I made one myself from some ally angle, a dozen bearings and some turned sleeves for the bearings. My advice to anyone else would be just buy oneThey weren't £20 when I made mine, more like £50. I tried it with just the bearings to start with and it put facets on the OD of the pipe, but I'd sunk enough time at that point that it was worth making the semicircular sleeves for the bearings. It really does improve the finish of the job no end though.
I'm think my old Pug 106 has them under the seat area to join pipes.Pretty sure i've seen male into female joins from the factory.
I had a mot advisory for grease on my brake pipes....................it was the mot tester who greased them about four years ago!Coat of underseal sploshed on top.
Sorted.![]()
Very tidy a credit to you those pipesIf you want to make a really nice looking job of it, as per Joepro's above, the pipe straightener really is essential.
As for galvanic corrosion, it only occurs in the presence of an electrolyte. An assembled joint is gas tight. I wouldn't worry about any corrosion on the sealing faces.
