The_Yellow_Ardvark
- Going Away.
Another one.
Mine's very inaccurate, even over the first link. By the time you are out to one pole, it's completely wrong.
Should see the zoomies and flopping like a fish he does on the sofa after drinking water, can't imagine the carnage on ciderGoing by the look on Oscar's face he plans on drinking those himself!![]()
Don't volunteer to strip and service the 3 speed gearbox on a makita cordless drill. It is a complete bstd to put back together.Also acquired the "ahh that hard..." part of "how hard can it be" to strip and repair this hilti te80
I don't think it's meant to be banana shaped lol
Got this te80 and a te60, both power up and spin the motor but neither hammers or drills, the conrod is broken so that solves the hammer part and as for the drilling I think the last person to "service" it put it back together wrong so gears weren't meshing and the bore the hammer piston slides in had the pressure holes on the wrong way so it was pretty much running like a diesel and thus pressure broke the nylon conrod!Those TE80's turn themselves off at service time and have to be re-set. If the spanner light is on then even once repaired it might not run. The earlier TE76 you could re-set the service light by powering it up disconnected from the motor and give it some sequence of trigger squeezes but I don't think you can do it with the 80.
Helps you breathe more easily?Some white powder for the weekends
They look like the gauges we use an air sampling pipes.Today I acquired some carb vac gauges, need these to set up some itb’s on some v8 silliness, also need to build a manifold and check they all read the same.
Bob
English torture machine, start with the fingers...Saw this being taken to a skip, so I offered to help them, gave them some folding money.
£10.
Bob
Bit of an awkward font, especially on the cast back, but it's a Lucas Masta gauge, made by Lucas. The script S is the opposite direction to an ampersand. It's probably tripled its resale value nowA 3" tyre gauge MA&TA Birmingham maker
Look for Gbh5dce Conrod 90% will fit .Also acquired the "ahh that hard..." part of "how hard can it be" to strip and repair this hilti te80
