I hoped I would be able to carry on where I left off, I am glad to say that the ease of maintaining a good weld due to the virtually straight lead, allowing a smooth flow of the wire, really did prove invaluable.
I felt my torch angle was a little to far away from perpendicular,
I tried a more steeper approach today, and on the face of it, it has made a significant difference.
I'll try it again tomorrow.
hopefully will add a little more strength.
i can make a start on the wishbone and their polybushes. i'll be doing a build thread on here and on MX5Nutz forum.
(what I first thought was a little rusty bit.
) It turned out to be worse than I feared.
(sounds familiar
) So I decided to try and practise small hole filling. I mean, How difficult can it be? and as Arnie once said, "BAD IDEA"
Read Marko's thread about his experience of polybushes on the MX5Nutz forum.
Helped him replace them with OEM bushes last month.
they come in two bush halves and a steel insert. To fit them properly you need to drill and tap the wishbone and fit a grease nipple to be able to grease each bush annually.
OEM bushes are good but so expensive compared to decent polybushes
but enough to finish off the upturned lip and grind back the earlier welding.
Even managed to get the acid etch primer to dry, with the help of a hot air gun.
I decided to put all my previous lessons together, IE torch lead being a smooth large curve, angle of torch being closer to vertical and also positioning myself so I could have the torch in line with the weld.
may be a bit high though.
so while I had a little light left, I went for four more coats warming the panel between each coat.
I don't do restorations and only do mot repairs when i have to ....i hate welding cars
I'll try not have to much time off over Christmas,
wild horses and all that.
I was torn with the fact that once the rap around bumper was re fitted it would not be visible. that said, i was still disappointed with myself for not making a smoother job of it,
and may revisit the area again. After all, if a jobs worth doing it's worth doing well.
