BrokenBiker
- Newport, South Wales
i have a mamod engine, used to be my grandfathers, then given to my father and has been in my posession for about 8 years.
when it was given to me the pressure relief valve was damaged and leaking meaning it couldnt build pressure, it was replaced with a whistle that wasnt for this engine which again, hindered it running. i have since replaced it with a repaired pressure releief valve and that works well again minus the fact i havent got the fuel tray for it so i usuall run a torch on its lowest setting and set it far enough away that its not getting too hot too qucikly, to try and mimick running it on meths.
i have been deathly ill over the last few days and upon feeling a bit more energetic today i decided to get it out and have a play, maybe clean it up a bit and ive noticed 2 things. the pipe leading to the ram has come loose from the steam chamber, the soldered joint has failed, no big deal i can fix that easilly, however the other noticable thing is that there is now a rattle coming from inside the steam chamber.
does anyone know what may cause this as i didnt think there was anything inside there. im wondering if its just a bit of solder that dropped off when this joint broke but that seems unlikely. im hesitant to sweat the chamber apart to remove it, but everything else looks intact. the rivet holding the mount for the spinlde is still solid and thats all i can see that enters the chamber.
