electric or manual start out of interest, I had a single cylinder petter more or less the same, I preferred rope start than the starting handle.Just dragged an old welder out the shed that hasn't ran in at least 10 ten years. It's got a 2 cylinder Peter's engine turning fine and nearly kicked up .What's best to put down the 2 little tubes that inject into engine to help it start?
Manual start. Got it going today had a bit more umph in me this morningis it
Just got 2 little levers that hold the valves open slightly to decompress. What's a countdown decompressor?I just used to put a little engine oil in them. Worked fine. Does your engine have the countdown decompressors (BA2)?
Is the engine a Petters PH2?Just got 2 little levers that hold the valves open slightly to decompress. What's a countdown decompressor?
i have a knob on my briggs and stratton diesel engine you click it once and the engine is decompressed . when you crank it over it turns and clicks for 7 times then compresses and startsJust got 2 little levers that hold the valves open slightly to decompress. What's a countdown decompressor?
I've no idea. I'll have a look for a number tomorrowIs the engine a Petters PH2?
Similar to what brightspark says. On the Petter twin that I had, you moved both levers to the decompression setting and as you turned the engine over, you could hear them clicking to the compressed state by which time you had hopefully got the engine turning over fast enough to fire. Often referred to as 'countdown starters'Just got 2 little levers that hold the valves open slightly to decompress. What's a countdown decompressor?
Or wrist breakers. Often referred to as 'countdown starters'
I had a friend with a 2 cylinder Bedford rascal or similar, it never ran right, partly because he was forever fiddling with the mixture. Anyway, he had it rebuilt, thing wouldn't run on both cylinders, so he asked me and another mate to check it out. Sure enough, only one cylinder, despite sharing the carb, spark was good, cam was good. So we poked the cast iron exhaust manifold - blocked solid...Had a Petters PH2 in a dumper that would only run very very roughly. One of the causes was a completely blocked (with carbon) exhaust port. I was told the cause was standing ticking over whilst the driver/s went to tea/meal breaks.
Norm.
Had a look it's a ac2Is the engine a Petters PH2?
Good engines, although the AD2 is better... easier starter being direct injection.Had a look it's a ac2
