Is that a Pytchley? The sliding roof on my Morris 8 is and it's made from wood.Someone decided to use filler and fibreglass to repair the Austin Seven sliding roof frame but I prefer steel.
No seals? I've also brought the sides of my top down to give more protection from the rain. I had mine coated, but have since added a couple of strap points to the front.I didn't want a full blown top box but my Kriega US20 bag was getting full and I needed some place to store tools, pump, puncture repair kit etc.
Made up an aluminium box to fit on the rear rack and fitted the rack plate I had previously made to the top of it.
Test fitted it today to see if I liked it, I think it is ok but will look fine once it has been powder coated black.
View attachment 482890View attachment 482892View attachment 482891View attachment 482893
It is just a test fit to see if I like it. Once powder coated I will put neoprene on the lid to seal. Everything inside will be in small dry bags as well so should be fine.No seals? I've also brought the sides of my top down to give more protection from the rain. I had mine coated, but have since added a couple of strap points to the front.
That is really kind of you but I really only need the one and it would likely just sit around doing nothing.@Hood
If you’d like another Kriega US20 to strap onto your existing one, I have one here that I never use anymore.
Bought it years back and used it once on a trip to the Ardennes and it’s been in the cupboard ever since!
Not sure I’d be allowed to advertise it on here - it’s not workshop equipment or tools so I suspect the mods wouldn’t approve it.That is really kind of you but I really only need the one and it would likely just sit around doing nothing.
I am sure if you offered it up here there would be someone who would use it.
Are you going to have a rack on the lid of the box so you can strap the Kriega (or other stuff) on the top?I have been looking at the tail box I made for the bike and the downside to it was the lock and catch were taking up a lot of internal space.
I did a bit of searching and found this which looked perfect.
So I took out the lock and immediately I could pack more stuff in.
In the 3 drybags I have a small toolkit, puncture plug kit, pump, pressure gauge and jump starter, so pretty happy as that was all the stuff I used to carry in the Kriega.
Now all I need to do is make a new lid, weld a plate for mounting the lock then get it powder coated.
Oh you can also see the neoprene seal I tested out, it will make it water tight as well so the dry bags are probably not even needed.
Yes as per pic a few days back.Are you going to have a rack on the lid of the box so you can strap the Kriega (or other stuff) on the top?
I carry one of these as they are so small, tested but not used in anger.I have been looking at the tail box I made for the bike and the downside to it was the lock and catch were taking up a lot of internal space.
