I didn't order an entire plating kit from Caswell Plating---just their chemicals. I put together my own set of hardware and other supplies (power supply, timer, heater, baking oven, aquarium pump, anodes, anode/filter bags, etc.) from various sources, both new and used, and saved some money, and I use some of the items (power supply, pH meter, baking oven, measuring beakers, etc.), for other purposes besides plating, which sort of dilutes the cost of the plating setup. The chemistry lasts quite a while. There are ways to rejuvenate the plating bath, and chemicals like brighteners might sound pricey, but one small bottle is good for many batches of plating solution. If you have some time available for research, you may want to get a book on electroplating and make your own plating solutions to save more cash. The individual chemicals should be readily available. I used the Caswell chemistry because I knew it worked, and I didn't want to spend a lot of time experimenting with different solutions.Had look but the kits near £400!
Must be a cheaper way?
Thanks Its a pity I cant pop round and "throw my bits in your bath"I didn't order an entire plating kit from Caswell Plating---just their chemicals. I put together my own set of hardware and other supplies (power supply, timer, heater, baking oven, aquarium pump, anodes, anode/filter bags, etc.) from various sources, both new and used, and saved some money, and I use some of the items (power supply, pH meter, baking oven, measuring beakers, etc.), for other purposes besides plating, which sort of dilutes the cost of the plating setup. The chemistry lasts quite a while. There are ways to rejuvenate the plating bath, and chemicals like brighteners might sound pricey, but one small bottle is good for many batches of plating solution. If you have some time available for research, you may want to get a book on electroplating and make your own plating solutions to save more cash. The individual chemicals should be readily available. I used the Caswell chemistry because I knew it worked, and I didn't want to spend a lot of time experimenting with different solutions.
That reminds me that I'm just about ready to plate another batch of fasteners and other items. Maybe this weekend?![]()
Can I join the queueThanks Its a pity I cant pop round and "throw my bits in your bath"![]()
If you're ever on this side of the pond and have a suitcase full of parts to plate, feel free to stop by.Thanks Its a pity I cant pop round and "throw my bits in your bath"![]()
If it's done correctly, it should hold up as well as the original zinc plating (I think). The longer a part remains in the plating bath, the thicker the zinc builds up, and zinc anodes are pretty cheap, so no need to skimp on the zinc. When correct tolerances are important, it's even possible to have too thick of a zinc layer. Also, the post-plating chromate passivation coating adds a lot of extra corrosion resistance.@Blue Chips am really interested in the longevity of the plating
Very cool old machine!I picked up this a few years ago but still haven’t used it
