winchman
- Merseyside
As I get older I am struggling with my present Rivet tool its like an old pop rivet gun
So what are others using?
Anyone tried these?
Anyone tried these?
Thanks its something thats so handy when you need it but I also don't use them much but Couldn't have set them without Winchboys help, so time to look for a tool thats easier to usei was using a bolt with 2 nuts for the best part of a long while, then my father bought me a similar kit to the one in the link. havent had any issues with it, but that said i dont do much in the way of rivnuts.
Sealy? Most I look at have short arm I suspect so they are cheaper top post?I've got a sedley short arm nut rivet tool - two longer lever type handle, easy to use even with steel rivnuts.
I've never found much info on actual settings - if I don't strip the thread out, then it's loose
I'm not a fan of the drill mounted versions. Hard to hold onto for a start.
Then, they are either cheap and rubbish or the good quality ones cost about the same as the proper tool anyway.
I've got a couple of pneumatic ones that might be looking for a new home (I've gone cordless now) if you use one enough for that?
Otherwise, this ratcheting type are really easy to use compared to having to squeeze anything..
Or even SealeySealy? Most I look at have short arm I suspect so they are cheaper top post?
Thats a good idea I might give it ago unless a long handled one turns up thats good quality and affordable for me as its not often usednext time mine see's daylight it'll get home made telescopic handles...
No!
Bob
Never used one but I want it to replace the long handle tong type I haveAs I get older I am struggling with my present Rivet tool its like an old pop rivet gun
Anyone tried these?
