Ratty
Putting the She in Sheds
http://www.bigtoolbox.co.uk/Products/000b00070006/MFX480QI
And they have the fasteners at a decent price.
It did take some internet lurking to find it though.
Chunko'.
Cheers!
Chunko'.
For realy confined spaces I use a HT caphead bolt + 2 well fitted washers all well greased (flange type inserts,) For c/sunk type you need to turn a thick washer with a small cone .
Rivnuts if not installed correctly can spin, and are not intended for continual use or high torque . Where this is likely these should be used Hexagonal type,
If you think the bolt will be installed/removed then a couple of tacks with the TIG should hold it fast
like Hank bushes?'swaging inserts' for.
Chunko'.
