Looks like you may want a few baffles inside your heater to stop just the one side getting red hot.
I'm already thinking of a steam engine and running my workshop from it.I'm going to fit solenoids to the oil and air lines connected to an optical sensor and controller I have from a home heating burner so if it goes out everything shuts off, just need to mount the sensor somewhere it won't melt.
I'm so grateful to you for poiting out this type of engine and to demag for telling us about his burner project. I don't know how I'd never come across Sterling engines before.
I've been meaning to try building a DIY oil burner for some time. I thought I'd use a jet nozzle from a domestic oil boiler for my first attempt. I see they have various sizes like 0.5 and 1.0 which I understand is gallons per hour. The nozzles also have a reference like 80S or 80H being an 80 degree flame, solid (S) or hollow (H). Would anyone hazard a guess as to the best type of nozzle to start with for a simple homemade burner? Would a hollow or solid flame be most likely to work well? Assume the oil coming in will be at pressure.
though not coal fired at a guess.
If I had a lathe ( Gingery lathe may be next project now I can melt ali )I might be able to do that but I'm going to get a solid ball, drill it out and fit a .6mm mig tip into it and then smooth it off.I was wondering if a towball would work, might be a bit awkward to drill?
