I can't get the video to work?
First thing I would do with an HF problem is check the leads (both of them)
Got a spare torch you can try?
It should be a YouTube video?
It is unlisted but as long as you click through it should work.
I don’t think it’s HF as the HF works on the DC side
I don’t have any spare leads unfortunately
Yup take some small side snips to the pins and cut each leg off it then desolder them individually. Much easier that way since it's kaput.Worth trying to change it?
Any idea on how to work out what it’s supposed to be?Definitely worth trying for a tenner in my opinion. You'd need to be sure it's a UC3705N though, there's a whole range of them with different voltages. UC3705N is 5v, UC3708N is 8v etc
BTW. This driver is for secondary inverter stage.
As written above positive sequence is not active.
But it seems that the bridge is not totally short.
You need to remove the driver and check both channels.
