The fuse specifically, but the socket still needed replacing after being subject to that.That looks more like a plug issue rather than a socket issue.
What does the plug belong to? Was it a chinese "fuse"?
It was a extension lead to the tumble dryer, probably over worked this time of year, i've ordered a new lead and changed the sockets as dad always has spares, 13 amp fuse i suspect in the plug, not something that was checked pre or post burn out !The fuse specifically, but the socket still needed replacing after being subject to that.
Improvise, adapt and overcome.While I was fixing the Surf I also used the old exhaust to prop up the side gate while I refixed the roller wheel
And never throw anything out.Improvise, adapt and overcome.
AbsolutelyAnd never throw anything out.
Sell the old wire for scrap and use that to fund the rewire.I've said the whole house needs a rewire, but the economic climate means there's no spare cash for anything at the moment![]()
A lot cheaper to run on Kero!Installed - another diesel heater post....
Located where I want it. Got the air and exhaust outlets cored drilled. Needed more pipework than supplied which was cheap enough. Got some 45 deg bends as well. Stick on measure so I can work out consumption. Cables tidied and PSU in cabinet below on a shelf.
View attachment 479416View attachment 479417
Waiting for some P-clips for the air pipe and will put a plastic hat on the comedy air filter intake as pretty sure that will get soaked/water in. Idea behind the pipe bends is that when its all clipped in place, I only need to disconnect 2 clamps and pull the whole thing away from inside to service or whatever. Have an air quality meter above it by coincidence and apart from initial exhaust pipe crap burn off it's clean as.
Been using it for about a week, draws about 25w on the PSU after initial 100w or so start up. I'm saving 60% over 2kw heater versus diesel consumption. I like the heat spread as well, kicks it out well and even RH seems down over electric. Well happy.
