BrokenBiker
- Newport, South Wales
so, my steel filler rod and pack of consumables arrived today so had an hour having a proper go at figuring it out.
ran 2 beads on some ally to just check the AC side of things, that works fine. no idea what grade ally it is, just sold as 'raw aluminium' in B&Q. second bead cracked right through as i was welding, not surprising but still, the AC works, as does the frequency and AC balance adjustment.
after that i went back to mild steel. better than i expected results, but obviously far from being a pro.
setting were:
100-120 amps
base amps 50, upslope 1 sec, downslope 1 sec, 6 sec post gas
5mm steel
no.5 cup
2.5 lanthanated tungsten
5lpm argon
first pic i had a few runs with no filler to get to grips with arc legnth. dipped it straight away as soon as the arc lit, obviosuly so shrapened and carried on. after a few beads tried adding some filler with varying results. these were all at 100 amps and i think i was holding too tight of an arc as the puddle didnt really grow nearly as wide as i was expecting and it was very difficult to add filler without hitting the tungsten, and i dipped it more often than i didnt.
dipped it on the last dab so changed the tungsten and just ran a few more over the top of the existing beads, but bumped the amps up to 115 and tried to focus more on a slightly longer arc so i had space to get the filler in to the puddle.
the top 4 beads are the higher amps, bottom 3 were from the previous attempt. happier with these, they have better penetration (i wasnt aiming for full penetration, but on the first few it didnt seem to be biting in, on these few the back of the steel was glowing) and a bit easier to see what was happening and control it a bit better. still nowhere near perfect, but better
stopped to let everything cool and grab a cuppa, then decided as it was bitterly cold and frankly i was getting bored of sharpening tungstens (links for electric tungsten grinders would be lovely) i thought id go for broke and try an actual joint. dont know what i was thinking though as i positioned it all wrong so was welding towards myself at a 45, rather than right to left the way i had practiced so was massively uncomfortable, wrist was rigid and the filler was rubbing on the side of my welding mask just to get it somewhere near the puddle...all in all a stupid idea but im good at those so kept it as it was and had a go. probably could have dropped the amps back down to 100, maybe a bit less as its only 2.5mm thick.
that said, its stuck and it aint coming off...it aint pretty, but neither am i.
i did also try the pulse settings, but only ran 1 bead as again just wanted to check it worked. set it to 1 pulse per second, 100 amps peak, 30 amps base and the duty (i assume that is the 'on time') at 50%. it worked, but it was during the stupidly tight arc phase and i think i was dipping it every time it dropped to base amps.
all in all, i learned a bit, had some fun, my torch hand is a lot steadier now and feel like i have gotten the very basics sort of down. a lot to learn, but ive got a lot of time.
still cant get over how quiet and calm it is on DC
setting were:
100-120 amps
5mm steel
no.5 cup
5lpm argon
