Not a good idea to lube an anchor. It will only slipSo the green anchorlube that all the youtubers seem to be pushing isn't very popular unless it's given to them to advertise![]()
I can't find the MSDS but IIRC it's basically soap with mica flakes in it.![]()
Anchorlube - World's #1 Water-Based Cutting Fluid
Anchorlube is the #1 water-based cutting fluid trusted by professionals. Experience a clean all-purpose metalworking lubricant perfect for all types of metals.anchorlube.com
Makes shiny threads on everything I have tried it on.
I don't think so.So the green anchorlube that all the youtubers seem to be pushing isn't very popular unless it's given to them to advertise![]()
I’d use it however it doesn’t appear to be as inexpensive as I would like.So the green anchorlube that all the youtubers seem to be pushing isn't very popular unless it's given to them to advertise![]()
Seeing how it's used sparingly with a squeeze bottle ( A little dab will do ya), just what is your "target price" ?I’d use it however it doesn’t appear to be as inexpensive as I would like.
Good points there @Erie Fred. In truth I thought about trying it when I next run low, but that was 6 months ago - and 2 things happened. 1 I forgot about it. 2 I was ordering some stuff and a ‘cheap’ option came up just after I got fed up with moving one tin from lathe to drill to mill, to drill etc.Seeing how it's used sparingly with a squeeze bottle ( A little dab will do ya), just what is your "target price" ?
and how do you put a value on saving taps from excessive wear using cheap stuff ?
Just rub it on the tap or the workpiece, really. Anyway, it works very well. Give it a try, and see how it goes...Do you mix it with anything - I have LOADS of it in various states from my beekeeping days.
In truth I thought about trying it when I next run low...
Thanks- that makes a lot of sense.One thing to consider in a more commercial environment is that your customer will not be happy if the parts you deliver are contaminated with cutting compound. That means that you, the supplier, may need to wash them before delivery to meet a cleanliness specification. Washing off a heavy, sulpher-based cutting compound is likely to cost you more (including disposal of the wash solution) than washing off something like wanchorlube, where soapy water can go down the drain.
A similar issue occurs with high production CNC stuff using flood coolant - then coolant management is a big issue.
These things are not considerations in a home environment, where time is not money and the EPA/DEFRA won't come knocking because all the local newts are lying on their backs with their legs in the air, but for a business a more expensive cutting compound (£ per litre) could have big savings elsewhere.
I will have a go. I also have some I mixed with BLO for polish that I might try.Just rub it on the tap or the workpiece, really. Anyway, it works very well. Give it a try, and see how it goes...
it's always down to money isn't it ?Good points there @Erie Fred. In truth I thought about trying it when I next run low, but that was 6 months ago - and 2 things happened. 1 I forgot about it. 2 I was ordering some stuff and a ‘cheap’ option came up just after I got fed up with moving one tin from lathe to drill to mill, to drill etc.
With the little work I manage in my workshop £20 vs £10 for CT90 is quite a leap. Or £5 for trying something else that might work just as well…
got a gallon of rigid thread cutting oil given its 35 quid a gallonI'm not sure how to read your reply - have I annoyed you Fred? Anyway, as you asked:it's always down to money isn't it ?
Do you factor in longer tool life ?
Do you factor in no smoke in your lungs ?
Tripping over pounds to save what ?
Not every comparison is done on percentages of price only.
I've got a tub of Rocol - but have 4 or 5 places I need to use it - and it's ALWAYS in the wrong place.i use a tub of the brown rocol it is the best but expensive if you fork out full price. got quarter of a gallon for 12 quid 20 years agogot a gallon of rigid thread cutting oil given its 35 quid a gallon
They sent me some as I’m a powerful instagram influencerSo the green anchorlube that all the youtubers seem to be pushing isn't very popular unless it's given to them to advertise![]()
its nice putting it in to a washing up liquid bottle as you can just dab a bit on the hole or threads. rocol do sell it in a squeezy bottle but its the red chlorine free stuff , in other words its crap like eveything else thats got to be none toxicI've got a tub of Rocol - but have 4 or 5 places I need to use it - and it's ALWAYS in the wrong place.
As I appear to be trying different things when I have some spare time (Early 2026 at this rate!!) I might just decant a little and mix some turps with it as you suggested.![]()
How come chlorine is so toxic when it is in useful stuff like Rocol and yet benevolent or even beneficial when put in our drinking water?its nice putting it in to a washing up liquid bottle as you can just dab a bit on the hole or threads. rocol do sell it in a squeezy bottle but its the red chlorine free stuff , in other words its crap like eveything else thats got to be none toxic![]()
