Ended up ordering a new switch but it will not arrive until 2025.Destroyed the stayer Len 200 switch attempting to loosen up the corroded screws.
1 screwdriver
2 hammer and screwdriver
3 impact driver
4 pliers
5 solder flux and soldering iron tempting to eliminate corrosion and transfer heat to make the flux run through the threads.
Didn't work
6 drill through the wire hole to reduce the portion of the screws that I've eventually drilled through.
Unfortunately the brass insert break a part.
Not a fail it's still salvageable.
I'll solder small length of wire directly to it because a similar switch apparently is more than 80 euro plus I have no time to waste waiting for it.
Prior to this little step back I've successfully soldered new wire to the stator windings because they were completely rotten.
Called the day.
I still have 2 days to achieve the goal otherwise it would be for Friday
The result is very cool thoughI've been playing with AI stuff again, which has distracted me from doing some more important tasks, but one needs a distraction once in a while.
I thought I'd try making a 4K-resolution steampunk screen saver. I started by asking Firefly to generate a steampunk-style image full of pipes, valves, and gauges, all in one pass.
The result (below) was interesting, but I was disappointed in the distortion and lack of detail in many of the features.
So, I then used Firefly to generate individual replacements for the gauges and other features. Creating them individually greatly improved the detail. I also used Firefly to generate a number of new features, such as lights, steam jets, buttons, etc. The image below (with the original image dropped out) shows many of the individual features that I replaced or added with Firefly.
Below is the result of the combination of the original image and the new individually-generated features. Note that there was a lot of trial-and-error involved, since not all generated images integrated well, and I also did quite a bit of retouching.
