Since I've had my partial refund, every time I try it, it works. I haven't tried to do any work with it though, so I'll have to take it back to the shed and try it.
Mine is the mains one from Aim Tools. Had it a few years. It doesn't get used a lot, but damned handy to have aboutAfter reading all this disappointment,what about the blue and black mains job,didn’t AIM TOOLS market them?
I don't bother pushing the centre out, just centre the disc& squish it. Works fine for meI am now super happy with my little Bosch 12v
It's really quite dinky but is still packs a punch. Thanks to @hotponyshoes I have a range of accessories now (I bought a bare unit off eBay for pennies) and an LBoxx to keep it all tidy.
The tiny size means you can use a powerful disk grinder/cutter on smaller or more fiddly items. The very solid steel guard means you can safely manipulate the tool closer to the blade without the risk of chopping your hands off. Good for precision work.
Note. The 3/8" hole centre does not fit the 10mm arbor. I bought a big pile of (cheap) cutting disks that came with a load of other types of actual 10mm accessories. The cheapo "Si Fang" disks do not fit. However if you were daft enough to try it, pop off the metal centre ring, they do fit....
I feel like every time I come on here I end up spending money...does look very nice . Bosch also do good soft bags too.I am now super happy with my little Bosch 12v
They do a nice soft bag...just big enough for drill, battery and charger.As in tool bags?
Do you know how it compares to the compressed air versions of the same?It's really quite dinky but is still packs a punch
I have both straight and right angle air cutoff tools, and love them, and if that's comparable it would be handy for work away from the workshop.
, yeah, let's clear it up.use 3.6 volt, hence 10.8 volt
I've been following with interest.
I have a Bosch laser, and it takes (apparently) 12 volt battery box.
But here's the thing, how do they make up the 12 volt? And here's a confusing advert from Axminster Bosch GWS 12V-76 EC Mini Grinder 10.8V (Body Only)!
If they are using 3.7 volt 18650, then it's 11.1 volt. If they're using 4.2 volt 18650, then it's 12.6 volt. But there's also a belief that they use 3.6 volt, hence 10.8 volt. Confused, yeah, let's clear it up.
What are they using and what's the voltage, well let's see.
Here are the pieces I used... Bosch 12 volt battery with an appropriate Bosch charger.
While I was at it, I grabbed a Makita (10.8 volt) battery out of the drill. Not fully charged, been sitting a few months (but not an original Makita battery).
The results ...
Bosch
Makita
I'd guess they've got 4.2 volt 18650 cells, allowing for over-charge protection components, reporting 12.4 and an older used 12.24.
Who'd have thought, eh? View attachment 497250
