JOEPRO
- UK
That’s going to be fun actually setting the arms under the car with the walls being so close , hope you have enough room to get from front to rear
Have you actually got enough room to (for example) pull a half shaft, or wield a BFH against something down the side?
The garage is the same width now as it will be when the lift goes in! I can do anything I need inside that existing garage.
The lift itself and setting arms will be 100% fine. The lift is not being altered in any way in terms of it's intended width.
It's just that I have no working space beyond the lift posts which is a limitation in this existing single garage.
A narrow garage with a lift is still an improvement from a narrow garage with no lift.
Clearing lots of stuff that was piled into this garage. Slowly making progress now with 3x shelving bays down.
