No replaced it with a Chinese android one. Fitted a few in the past but this is first one with DABMk6 golf? Sure it doesn't already have one?
I fitted one of those to my Fiat Doblo and found, whilst it worked, the number of DAB stations and consistency of signal wasn't as good as the windscreen foil mount.The other useful option is a DAB/FM amplified splitter. That allows the existing aerial to feed the DAB input. Not quite as efficient as a dedicated aerial, but sometimes compromises have to be made. The BMW motorcycles for instance, where fitting a dedicated aerial is impractical. The factory whip works well for both.
I fitted one of those it works brilliantlyThe other useful option is a DAB/FM amplified splitter. That allows the existing aerial to feed the DAB input. Not quite as efficient as a dedicated aerial, but sometimes compromises have to be made. The BMW motorcycles for instance, where fitting a dedicated aerial is impractical. The factory whip works well for both.
is there a prefered good quality brand or seller to use ? i susepct many are made in china cheapies?The other useful option is a DAB/FM amplified splitter. That allows the existing aerial to feed the DAB input. Not quite as efficient as a dedicated aerial, but sometimes compromises have to be made. The BMW motorcycles for instance, where fitting a dedicated aerial is impractical. The factory whip works well for both.
I've fitted 2, a Kenwood one that came with the stereo and works brilliantly. And a cheapo Amazon special that's about as much use as a bent coat hangar.is there a prefered good quality brand or seller to use ? i susepct many are made in china cheapies?
They all seem to come out of the same factory. However some work on arrival and some don't, it is the luck of the draw. Get it from Amazon and there won't be an issue to return it. I have seen about a 10% fault rate.
