I suppose it could come down to which material are you happiest welding.Last question I can buy all the materials in 304 stainless for around £100 or aluminium for around £150
Leaving money out which is going to be the best material for the job
Know anyone with a 3d printer? These are printable versions of the plastic snap together exhaust bend prototyping kits, but 3" and other diameters.Was thinking about that but don’t think i could bring myself to it as it’ll just look a bit like a bodge I could use it for mock up though to save the risk of wasting the metal pipe
 www.thingiverse.com
					www.thingiverse.com
				I actually do have one as well might print a set thanksKnow anyone with a 3d printer? These are printable versions of the plastic snap together exhaust bend prototyping kits, but 3" and other diameters.
3.0" Exhaust bend snap fabrication kit v2 by XeonDesigns
A 3.0" of my popular 2.5" mockup kitFinally a simple way to mock up and layout custom exhaust designs.I designed this system similar to my header fabrication kits.Makes exhaust system planning and layout a breeze.Complex compound bends and miter cuts are no longer hard to figure out and test...www.thingiverse.com
Either or really my stainless is probably slightly neater but I’ve gone for aluminium as I think it’ll be better than 304 for being in a constantly damp environmentI suppose it could come down to which material are you happiest welding.
For salt water 316 is best!Either or really my stainless is probably slightly neater but I’ve gone for aluminium as I think it’ll be better than 304 for being in a constantly damp environment
Certainly is but for fresh water and my budged aluminium is better same stuff in 316 was about 350-400 and since it’ll be mounted to a aluminium engine I thought just stick with allyFor salt water 316 is best!
Where does one get to play jets skis in fresh water over your way?Certainly is but for fresh water and my budged aluminium is better same stuff in 316 was about 350-400 and since it’ll be mounted to a aluminium engine I thought just stick with ally
Scotland I’ve got a caravan just past Dumfries on a lochWhere does one get to play jets skis in fresh water over your way?
Ahhhh Loch Ken?Scotland I’ve got a caravan just past Dumfries on a loch
No its auchenreoch lochAhhhh Loch Ken?
