Brad93
- Essex, United Kingdom
Three hours last timeBut they still expect you to fix it in a few minutes.
Just say "No!"All the friggin' time! And the worst part is I'm getting older so some jobs now knacker me more than they did, especially my lower back, and I still insist on doing them!! I can only think I'll have to sell some of my kit off so I can say "nope, can't do that, haven't got the right tool" when asked in future!!![]()
Unfortunately whilst ecp do indeed sell brembo pads, they are nothing like the pads you buy elsewhere, very poor quality made to a price specified by ecp...Car a bit safer... I'm aware modern brake pads have a strip of steel as a wear notification. When they get low they should squeal as it rubs the disc.
I remember garage pointing them out when discussing brakes, last time it needed rear calipers. We estimated the front pads would last a while longer than they have! Seems I no longer had the squeal indicators.
Last night heard a low rumble on the way home, it was the unworn rim of the discs rubbing against the pad backing! Very low.
New pads fitted, these are the old.
ECP had three options, I went with Brembo at £61, probably should have got the cheapies at £35 as the discs are not in great shape, back side of the discs appear to not be wearing evenly. Could use a bigger lathe to recut them flat.
Perhaps I could spin them up on the car and use grinder.
Really? Do you have any evidence of that?Unfortunately whilst ecp do indeed sell brembo pads, they are nothing like the pads you buy elsewhere, very poor quality made to a price specified by ecp...
Personal experience on the race car. Set of genuine road spec brembos from another supplier, lasted 8 race meetings. 1 set of allegedly same spec pads from ecp, turned to dust and dead halfway through the day and massive brake fade after 1st corner.Really? Do you have any evidence of that?
I've used Brembo for many years now, never had a problem.
You know the rules Keith!Today i completed a composite mast for a sailing dinghy. The mast was a circular hollow one i made about ten years back using birdsmouth construction, basically 8 staves with 2 45 degree angles machined in one edge so they interlock into an octagonal hollow section. Then rounded off on the outside.
It was used on a fast 18ft rowing/ sailing skiff but proved to be a bit bendy.
I sold the boat a couple of years back but kept the rig as the new owner didnt want it. Of course last winter i acquired another boat that it fits.
So today to stiffen & strengthen the mast i applied a carbon fibre braided sleeve to the mast & epoxied it . To do this 12mm holes were drilled into the top & bottom to allow rods to be driven in that rested on ball bearing rollers. A 24v murex mig welder wire feed motor drives a 4:1 reduction via chain so the mast revolves slowly. This ensures the resin doesnt run all to one side & leave resin starved areas on the top.
All went well & it looks good. Too much sticky epoxy & two pairs of gloves meant no photos today but i will get some tomorrow!
A one off? Italian quality controlPersonal experience on the race car. Set of genuine road spec brembos from another supplier, lasted 8 race meetings. 1 set of allegedly same spec pads from ecp, turned to dust and dead halfway through the day and massive brake fade after 1st corner.
I've just tested it, and the float..er..floats.Does it still float in fuel? I have tried to do similar before, and it didn't float after modding
Pity you were not local you could have chucked then on my lathe. If you excuse the pun.Car a bit safer... I'm aware modern brake pads have a strip of steel as a wear notification. When they get low they should squeal as it rubs the disc.
its a well reported issue on owners clubs and trackday forums.A one off? Italian quality control![]()
Brembo aftermarket braking stuff is pretty mediocre, and is purely relying on the name to sell.Really? Do you have any evidence of that?
Are you working for Nortn Korea or Elon Musk ?Been rolling a load of cones this week, various sizes and taper angles.
This is one of the more awkward ones.
Design decided to have the door laser cut in despite my advice not to.
You can see the distortion around it.
