My Old Landy
Engineering Mayhem
- North Lincs
A 300mm tall stand for our sticker packs we sell at craft fairs. I printed it in two halves and used super glue to stick it together.
) which is housed in the bottom and connected with a 2:1 belt reduction which then drives the 4.3:1 planetary reduction in built into the pulley using RC car components giving around 10:1 but the main version will be drill powered and more compact without the motor and the drive shaft is a shoulder bolt so hex bit slots right in.
Is that TPU?Out with the old and in with the new! Hopefully the table should drain under the glass now.
View attachment 469955View attachment 469953View attachment 469954
Nah just pla+, original is some years old rubber and most had perished so glass was just sitting on frame and water wouldn't drain so quick print to fix.Is that TPU?
No as much as petg but good enough for this useIs pla+ uv resistant?
Nice Mauser without the broomhandleA good friend of mine is a massive Star Wars fan so for the last few days the printer has been busy making him some gifts
Look it's the dreaded 3d printed ghost gun politicians keeps crying about!A good friend of mine is a massive Star Wars fan so for the last few days the printer has been busy making him some gifts
My mate did that 25 years ago .Tunnel extension for a catflap to bridge a cavity.
People didn't believe me several years ago when I said we needed to have a fixed hot climate inside a cabinet to get good prints as the slightest air movement could kill a print if it had any height to it .A frame brace designed for a voron printer in green abs. I cut the grow tent frame down to suit the space better, and give myself some slack to pull the top centre into a peak, put a hole with a small eyelet in it and feed the filament in through that from outside. Its only a temporary solution but it works great and no odour in the room.
I've tried to print this brace before in abs, and its always detached from the bed a few hours in, but now no warping at all. Its for the ender's frame, and attaches with hammer in tee nuts, but lets you leave any corner braces already fitted in place too. Just another 7 to go. I'll fill the bed and print as many as plater can fit in one go now its working and leave it printing overnight.
