rcx132
Philip
- London, UK
Modern oils (Non-synthetic/semi-synthetic/fully synthetic are ultimately marketing BS these days) don't burn as easily and have a higher shear, which means they remain on cylinder walls longer compared with old oils, and don't scrape of as easy. This can reduce oil consumption, however you do risk bore glazing, especially on engines that aren't worked hard from new.
I ran this past ChatGPT on the same thread where I asked it if Synthetic oil is ok on my older cars:
This concern is minimal unless the engine is rebuilt or new. If the engine has many miles, synthetic oil is unlikely to cause bore glazing unless the car is rarely driven hard at all. Regular driving should prevent it.
There are a lot of claims out there. You cant believe them all. If Mobile 1 is willing to warrant their synthetic oil on my old cars, I'm fine with that.
The detergent effect is apparently more true:
The claim that synthetic oil can "dislodge old grime" in an engine is partly true, especially for older engines that have been using conventional oil for a long time.
Synthetic oils contain more effective detergents and dispersants compared to conventional oils. This can:
Clean deposits: Synthetic oil can gradually dissolve old sludge or carbon deposits, which might have built up over years of using conventional oil.
Potential clogging: In some cases, if an engine is heavily sludged, the cleaning action of synthetic oil could loosen large amounts of debris, potentially clogging oil passages or the oil filter.
To mitigate risks, it's advisable to:
Use a synthetic blend first if you're concerned about a sudden switch.
Change the oil filter more frequently when switching to synthetic in older engines.
Monitor the engine's performance and check for leaks or signs of clogging.
