DAPPH
as dyslexik as I'm daft
I often help Fizzy down at his place , one of the things he's found is certain long abrasive belts for his industrial vertical linisher are expensive . I too have found the same when I want a harder belts for my small linisher .
Both of us have seen some YouTube vids of jointing the new cut to size abrasive belts up . If any of you have successfully done this would you lease tell us what adhesive or flexible adhesive super sticky tape you used & where you got it from .
Mean time I've ordered a few sorts of tape from Temu and will experiment on my machine with some old well worn belts , I'm also thinking of using flexible nylon ( melted cable ties in a simple bolt up home made press when it's just at the nylon melt point on n the pressure plates with nylon between the chamfered scarfed lapped joint to fuse it together .
Any useful suggestions or tips are most welcome .
the rest is easy
