arther dailey
- England
Ok, engine rebuilt , injectors taken to get checked, all tested ok, when I went to refit one of the caps the wiring plugs into was at a jaunty angle ,rather than square, thought strange but as it just passed fitted it (dreaming) although it wasnt when I took it in for test. Yes I should have known bettter /
engine fitted , fired up, delphi on it and it has fault code cyl 1 (that injector) inj circuit present (fault ) sounds like its on 3 cyl untill 18oo rpm when it sounds right .
my question is how can I check loom ok and no fault there , as it says on readout, circuit not injector , because otherwise it means stripping down top end to get injector out .
I realise these are triggered by low volts but not how to test , apart from pulling plug of and trying but that would just prove fault on no.1 but I already know that . all and any advice appreciated , no mot so its gotta be done on the driveway.
) asked seller if per chance they have record on sales listing.
