addjunkie
- Northumberland. Reet oot in the sticks
I agree, you use far more chains with the grinder too.I disagree , I can sharpen a chain better than one of those machines.
How did you sharpen the harvester chains?
Mainly by hand but if i had a few to do I some times used the sharpening machine.I agree, you use far more chains with the grinder too.
My two cents worth. Yes you can sharpen a saw with a file and if you can get good quality files they can do several sharpenings. The rotary stone sharpeners out on site can also do a good job. Both of which I take with me out on jobs, however, the best option I found is take several chains with you which match your saws and swap them out. When you return, sharpen all the used chains so they are ready for the next job. My electric sharpener, now that I have used it several times produces a much more consistent, sharper and better cutting edge that with either a file or rotary grinder. Even including setup I can sharpen a chain faster and better using my electric sharpener, not to mention having two three or even four chains to sharpen. If there is no alternative a file will do, but on my return all chains are ground for consistancy. If you sharpen using a grinder and the chain is not sharp, you are doing something wrong, or there is a problem with the grinder.
Where do you buy your chains from?I have a box of cheap chinese chains, most cost only 70p each (fit the 020T) some £2.50 each (372XP).
I've tried watching some of his reviews but man it is hard going it's like trying to listen to someone who's taken dieretic suppositories orally. If he could do an entire review without drawing breath he would.
Project farm provides the best reviews around. I think he does a great job.
Why use the 201T when you have many more suitable saws for ground use?I have a MS201T saw which I use for firewood duties.
Thanks @KramThe cheap ones, Amazon and Ebay. Cant see anything worth while right now but they pop up occasionally.
