Arc Tourist
- Wales
Ahh, wall mounts. Ok, missed that.
12/24V? Might potentially be interested in them depending on price.Are those wheel chair motors ?
I saw an unused pair yesterday and thought someone might be able to make a decent kiddies truck out of them .?
I'll put their contact details in a PM for you .12/24V? Might potentially be interested in them depending on price.
Where would we be without bandsaws....Knocked up these death trap axe stands aswell yesterday.
They done me proud todays well
Again using off cuts and bits i have lying around.
View attachment 468079View attachment 468080
View attachment 468082View attachment 468083View attachment 468084View attachment 468085View attachment 468086 View attachment 468087 View attachment 468088 View attachment 468090
Good migging there - what welder do you have?
Interesting, do you know what species? If you are fitting please get more photos.Some limb supports for an exotic tree.View attachment 468251
Catalpa,an Indian bean tree.Interesting, do you know what species? If you are fitting please get more photos.
Something to consider for next time, if they are intended to be permenent, as the limbs grow the supports will choke the lower side of the limb before in several years, becoming encapsulated. Where it chokes it will squash out the cambium until it can callous around and over the plates.
For that reason I suggest the supports having a lower contact area. It may be better for the tree in long term to drill it and fit a 20mm stainless threaded bar or similar as it would be a much smaller wound.
Note I said think, unlikely any would have happened.MX5 seat?At a loose end today so decided to chop the roller tool, I had made for the press, into two bits and then cut some 16mm steel up to make new parts so that it is now adjustable. Also cut some 25mm up to make a base for it.
The plasma still making a brilliant job of cutting, this is the edge on the 25mm
Very little bevel.
Tool on the press with a top tool I just made up.
As I didn't have anything to do I thought I might as well test out the adjustable tool so drew up some footpegs in fusion, cut some 4mm stainless on the plasma then welded them together.
View attachment 468330View attachment 468331
I made them longer and wider than the aluminium ones I made previously, not sure if they will be better or not but at least I filled in my time today, if I hadn't done them I might have been forced to think about doing some tidyingNote I said think, unlikely any would have happened.
Nope, Subaru Legacy Spec B.MX5 seat?
D'oh!Nope, Subaru Legacy Spec B.
No they’re bicycle conversion kit motors so they work on normal bike chains and sprockets so I can tweak the top speed by changing the ratio of gears. I haven’t needed to, it’s plenty quick as is.Are those wheel chair motors ?
