Maximal
New Member
- Drammen, Norway
Hello.
I'm a little worried. Long question, but hopefully there are some people in this forum that has a lot of knowledge and experiences on this.
I started welding on hobby projects back in 2017. Mainly cars from 1990 and older. It's not mainly galvanized steel, I suppose, but maybe a little. I have always worked outdoors, maybe once in a garage on the door opening. I use flux cored gasless welding wire in my machine. If I add up all the hours I have done active welding (you know it takes a lot of time to cut materials etc.) then I may have welded a total of 20 hours constant since 2017. This summer I did some welding on an 80s Dodge van. It was over a period of 4 days that I welded, but with a lot of breaks along the way. I used a dust mask when using an angle grinder to gut metal plates, but no respirator when welding. I also tried to avoid the smoke cloud, but I still got some I guess. Since then, I have felt a little tight in my chest and feel that I have a little more mucus than before. When I cough (on purpose) it's a slightly harder cough deep in the chest than before. My question is, could those hours of welding have done permanent damage to my lungs, or am I just worrying unnecessarily? I tend to worry about these sort of things. Similarly I have in the past not always used a mask filter when angle grinding, but I haven't done it that much and also always been outside.
I'm going to see the doctor this week, but I'm just so worried. I thought it took a lot more to do damage to the respiratory system, like working with this stuff every day for months or years. I can't recall that I've ever had "metal-fume fever" symptoms after welding. Maybe once when I was soldering some stuff, but thats ages ago.
Any answer is greatly appreciated!
In any case, I will always use a respirator for a next time.
