Oh yes it's mental really!Crackers isn't it that there's a cable running up the hallway wall thats fused at 300A. One of the houses it's buried in the plaster.
A fixed link on the neutral?the incomer has 2 porcelain fuse holders in it with rewirable fuse wire
Whats the likely size of the substation fuse on the other end of the incoming PILC?..
scottish power came to a job i was on to fit a new meter on to the new supply cutout. out came the rubber mat guy wearing full protective fire rated overalls big rubber gloves face shield and helmet pulled the mains fuse and fitted meterThats a good result then!
I'm surprised he's not wearing a full face visor and flash protection, the last DNO engineers that turned up to one like that had it all on before they went near it!
i said to him its a bit ott isnt it , he said if he didnt do it the bosses sneak round and if caught without its instant sack
They changed their ones to 25mm, I need to do from the DP switch when I do the boardare there tails 25mm or 16mm
you can buy a bag of them from ebay the thing is though you havent got the crimping pliers that are numbered and booked out to the fitter stamped on the crimps who last sealed them
said to him im not bothered if he says owt
what can he do once there back in . he wasnt bothered took the readings and left
