Erie Fred
- Erie, Pa USofA
I don't understand what that means.As said it has an internal freewheel so it can't turn backwards
Oh wow.So now we know... You don't want to drop it on your toes, and you don't want to get your fingers caught in it.. (My wife was in a hurry using the little toggle press the other day, and couldn't work out why it wasn't going down properly- so pushed harder - then realised it was her finger in between the dies,
To be fair she has limited feeling in that finger.. Cue pain and discomfort........ I don't let her play with the fly press or power tools.....)
Have you worked out what the pneumatics do?
I don't know of it is the correct term bR39Da used but the flywheel can be spun backwards but it is not engaged on the crank.I don't understand what that means.
Is this a single revolution clutch arrangement ?Turning the wheel backwards is a bit like a bicycle wheel, it freewheels and doesn't drive anything
Sorry, late to the show here. All I can recall about the mechanics is that the the die needs to be set up correctly, with the punch having just a fraction of clearance so it can fully cycle without mashing into the table when the die is empty.......................................
@Arc Tourist and @Beanwood have some experience with presses. Maybe you guys have a few ideas?
What can I try next?
Yes please! I presume the motor output is geared down to quite slow, or it's a sort of 'one shot' pedal, so it only spins and presses once - not at 1400rpmI might need to make a little video of it working so people who are interested can see.
(Although that may then make a marvellous - if small - planishing hammer.......or when a too thick piece is stuffed into it.....Sorry, late to the show here. All I can recall about the mechanics is that the the die needs to be set up correctly, with the punch having just a fraction of clearance so it can fully cycle without mashing into the table when the die is empty.
It didn't when I got because the 'clutch' was stuck at the top, it never made it to the trigger.If you turn it backwards with the trigger down does it engage ?
Why would you want to vary the speed on the motor ?Made a very quick video. Might make a better one once I have actually connected the motor up to a VFD.
I have set it up so that the 'clutch' is in the same position as when I got the machine (while it was stuck in the down position).
Not sure about class 4 or hi-slip, it is a 700 rpm 0.5hp, 3-phase 400V motor.Why would you want to vary the speed on the motor ?
is it a class 4 or hi-slip motor ?
When out hunting in Rattler country, make sure to urinate on the open and not into the brush or bushes.I found an old Bliss reference book (unfortunately too large to attach directly on the forum). Some interesting bits in there.
The safety section is a must read.
Here is a link.
Seriously.
Wow - you didn't hang about!!The little Bliss press is no more.
Had my fun and sold it on fb marketplace this afternoon.
The new buyer works for a company that makes disability ramps and he said they needed to change tooling too often. It is much better to just get cheap presses and have them do one job.
Thanks all for your help on getting it going!
