- Birmingham
I had similar years ago, put a GS850 frame in for coating, as the swingarm outer races were in blind holes I carefully plugged them to stop them getting blasted/coated, when I picked up the frame they had removed the plugs and coated the bearing racesDeath by powerdercoating..
On with a F800 GS.
Customer came in and said they'd had their F800 at a "Specialist Restorer!" and weren't happy it was safe (fork oil everywhere and he avoided their calls and wouldn't fix that problem).
Well...
Any time you have 2 mating surfaces together (brake disk against wheel, brake Caliper carrier against fork leg etc) it's not a good idea to have a massive sandwich of soft powdercoat between the two..
Had to go all through it removing powder coating from various mating surfaces.
I pointed it out to get "it'll be OK mate, the powder coat is that hard the bearings will run on it", I had to take the frame into work and split the races with a die grinder to get them out.
Upside was I asked my foremen if the company in Birmingham who supplied our bearings would have any, he said just call in and ask for xxxx which I did, they had got the bearings but when I asked how much xxxx said "you work for Rover so we'll put them on their account"
lol.
Here are several photos. Its a nice unit, and fits both 1" & also 7/8" handle bars using the supplied liner.
