Misterg
- North Wales
That's impressive!It's currently running for 3min every 25mins
ThanksThat's impressive!![]()
When I built my base unit for my galley kitchen, I surrounded my lpg fridge space with 40mm celotex/kingspan PIR board, then further sealed the fridge back (to try and insulate/isolate the vented space behind the fridge from the living space heat (& vice versa).Thanks
I would like to think the insulated unit I've built it into is playing some part, I'm back in making a draw for the unit on Sunday by then I should be onto 3 on the normal settings, god this data gathering malarkey is slow
It's all down to what ever suits you, I've made the unit to be as lightweight as I could so lithium was a no brainer for me simply on the weight saving alone, mine is just a camping pod and removable so I can revert back to the normal 8 seats and luggage when needed, I don't have the ability to fit a gas fridge and vent it as it's not fixed as in permanent, having first hand experience of 12v compressor fridge though I wouldn't consider one now.I was on a Self-Build Camper FB Group for a short while (I binned it when it quickly became obvious that is was a big p1$$ing contest, & the only course of action the "Moderators" tolerated was the "spend big" on huge LIPO banks, Solar Arrays, B2B Chargers, Induction Hobs etc. Lpg was derided as archaic rubbish that was dangerous (this from "experts" fitting heavy 300-400aH Lithium bands of questionable provenance & safety in some starship mileage ex-parcel van).
(There was any number of people on there being "advised" thus, & getting sucked into spending Coachbuilt type sums on self-builds - ending up with a vehicle worth realistically 30 - 40% of what they spent building it. Not for me!).
Quite a lot of posts I saw where people had expensive Lithium battery failures and issues (where the narrative was the big investment cost paid back with far greater life, greater usable capacity etc over Lead-Acid). IMO the lifespan claims, weight saving and performance etc don't match up with reality and the high outlay (at least not some of the time).... so I'm happy sticking with Lead-Acid.
My van build - is old school. Two "019" 100ah Lead batteries in parallel with a split-charge relay does my dc storage. No Solar (my last van had just 1 x 019 battery & I never ran out of juice once, & the battery lasted over 8-years).
3-way lpg fridge is silent & super cheap on lpg, and hob & grill are gas which of course reduces electrical demand considerably.
Modern compressor fridges are supposed to be very good. I already had 2 good 3-way & a permanent site, so it made sense to me to save the purchase price. In your situation I can see there's no better option.It's all down to what ever suits you, I've made the unit to be as lightweight as I could so lithium was a no brainer for me simply on the weight saving alone, mine is just a camping pod and removable so I can revert back to the normal 8 seats and luggage when needed, I don't have the ability to fit a gas fridge and vent it as it's not fixed as in permanent, having first hand experience of 12v compressor fridge though I wouldn't consider one now.
I will stick a pic up once it's complete, I've gone for a standalone 2 burner hob which is going to sit on a table that clips onto a rail, well it will once I've built it
That really does add up over time! (Looks like about 25A if the temp is 25c over 24- hours).Here's some manufacturer's data plotted for the National Luna 50L fridge:
It would be interesting to see how it compares with sg66's measurements.
Still over six days running the fridge only, at 25degC ambient temperature, off the 230Ah lithium battery from 100% to 30% capacity.That really does add up over time! (Looks like about 25A if the temp is 25c over 24- hours).
Am I working this out right???Still over six days running the fridge only, at 25degC ambient temperature, off the 230Ah lithium battery from 100% to 30% capacity.
200ah deep cycle batteries I was looking at were between 50 to 60kgThat really does add up over time! (Looks like about 25A if the temp is 25c over 24- hours).
A 100ah is only 10kg, but a 200ah is 50-60kg? Guessing the 200ah is much stronger kit & a proper deep-cycle build.200ah deep cycle batteries I was looking at were between 50 to 60kg
I think mine is 25kg the 100ah is only 10kg which had I known how frugal the fridge actually is would have done fine, dohhj.
Whilst I would like to say price was irrelevant it wasn't an issue, I've made everything apart from the fridge and sink and the price of pre made units minus fridge and battery were pretty hefty, when you added those in they became eye watering and are still generic, and no where near as light as what I've made, hopefully
Forklift batteries get loads of abuse. They are charged relatively quickly and deep discharged day in day out. They still last many years.Problem is 48kw is only around 24kw if you want it to last and it still will degrade quicker. Lead acid still has its uses but storage is not its strong suit. Also safety wise it depends on the chemistry. Lithium titanate is very safe and LifePo4 is safe. Also the new generation of solid state lithium are also safe. In general lithium batteries have a longer life, lower self discharge rates (important for back up systems) can accept a higher charge meaning quicker recharge either from solar or a generator if we are talking about home storage.
Price wise there is not a huge difference anymore. I would recommend used Ev battery’s as the most cost effective but there are some downsides. But even new LifePo4 cells you are looking at circa £100 per kw. So 40kw = £4000. And that’s usable (still best to only use between 10% empty to 80% but if you do use the full 100% they don’t degrade anywhere near as fast as lead acid.)
Good stuff! I'm in agreement with your cost-benefit analysis.... as you (& sg66) say, the main advantage is the weight.I think that's for 200Ah of lead-acid.
These are mine: Two Trojan T-105 6V 225Ah deep cycle batteries (aka golf buggy batteries).
28kg each, so 56kg for 225AH. (Something like 180AH usable on an occasional basis, but they've never been anywhere near that discharged. I think I've been down to 60% once in 5 years as the solar normally keeps up with demand.)
I considered lithium at the time of my build (2018/2019). Using a daily requirement of 40AH, the cost per cycle was lowest for the T-105s and cheap(er) lithium. I was less than convinced that the cheaper options for lithium would live up to their claims (I still am, really), but the Trojan T-105s have been around long enough for their lifetime to be well known and proven. They were £275 at the time (for both) vs something like £800 for a 100Ah Chinese lithium or £1100+ for a Victron 100Ah lithium.
This is the lifetime curve for the T-105. I'm hoping to get at least 10 years out of them.
If I were doing it again, I'd have another look at lithium as the 'real world' experience is building up, but wouldn't go bigger than 100Ah. I'd definitely fit solar (about 150W).
For weight saving, though, lithium really is a no-brainer.
As per my reply to Misterg above. Forklift batteries really ARE stronger as their output rating is tested & certified on much bigger loadings (& batts are far better at small loads over long duration than big loads over short duration). Ergo a (say) 200ah Forklift cell is actually significantly more powerful than its 200ah Leisure (C20) alternative.Forklift batteries get loads of abuse. They are charged relatively quickly and deep discharged day in day out. They still last many years.
Your 50% figure is deliberately pessimistic. 70 to 75% is more accurate. So how much for a 38kwh battery bank?
If they are still good enough for hunter killer submarines they should be good enough for most people!
The 100ah lithium 10kg the 230ah lithium 25 the 230ah AGM lead 60kgA 100ah is only 10kg, but a 200ah is 50-60kg? Guessing the 200ah is much stronger kit & a proper deep-cycle build.
Technically I have 200ah at 48kg (but not the same DoD though).
Pre-made Camper furniture is silly money indeed. Like you I made my own. (Unlike you mine isn't very light though... or that well-made - a cabinet maker I ain't!).
I'd be interested to see pics of your pod once done though for sure![]()
Out of curiosity, I looked up current prices:If I were doing it again, I'd have another look at lithium
Fogstar are way better on price than thoseOut of curiosity, I looked up current prices:
T-105s have gone up from £275 to £340 the pair. (225Ah lead acid)
Cost/cycle* : £0.10
Victron 100Ah lithium has come down from ~£1100 to £866
Cost/cycle : £0.12
Sterling 100Ah lithium is now ~500
Cost/cycle : £0.06
For the extra outlay, I'd probably go with the Sterling lithium (or equivalent) now, provided that user feedback was good.
*based on a 40Ah cycle.
