MattF
- South Yorkshire
Nick a pair of tights from someone down the pub and cut them into hammock strips for supporting your fruits
We still on about gardening?
We still on about gardening?![]()
By extending up another ring you get six feet or so run the tendrils round & up the ring anti clock ( to follow the sun ) .
Put a three or four inch water feed tube in the middle of the ring and have it poke out the mesh side , fill it with water twice a day with fertilizer if desired .Off to make two, 1m diameter rolls, stacked one on top of the other. These don't need guy wires do they? It'll really get in the way of future clearing operations.
I'm also going to need an extended spout or tube for watering. They get a watering can of plain rain water per day. Once a week an Organics plant feed.
They soon pick up after a rough handling if you water & feed them , be gentle with them and carefully put the tendrils round the wires as you wrap th plant stems round the rings /Right then, take two, 3' diameter and about 8' high. Staked at the mo with half a dozen of those 6" steel tent pegs you get with cheap, pop up tents:
Watering can needs an extension. I'll get my lad to print an adapter so I can use the rose:
I'm a tad concerned about these stalks / runners I've had to thread through the mesh. I cut the cable ties & removed the two canes that were in the blue tub. I then very carefully fed the leaves and stalks through the mesh. They look a bit wilted. Should I "threadle" them some more/tie/encourage?
Given it a good feed anyway.
Must shift the incinerator to the centre of that wild bit which is destined to become the veg patch extension.
If you do this it's easy to run more cane through the rings from one side to the other side use the tights or pop socks tied to the crossovers to support heavy fruits .
Recommendations please for a stainless steel digging fork and spade set please. I'm going to treat myself!
I 'm sure they go acw at the tip , Brrrrrrr. just got rather damp checking , all 24 bean plants on the two tripods run up the poles acw , I think it is because they also grow in the evening and the dark and climb round acw for the very early morning sun during darknessAnti clockwise? Really? Red dot is the squash tub. Sun goes from right to left:
Sorry I didn't say put the lower end of the watering tube inside the tub so the top ticks out out the side of the ring , pop a few slug pellets down in to the tubes , slugs & snails don't like the dissolved result .Won't that just become an haven for slugs, as in in the tube?
The end that goes in the tub should it exit into the soil or sit above it?
Ta.
Bulldog Tools made me a special set of long agricultural handled ladies border spade , a sugar beet gapping bladed hoe , a super lightweight garden rake and a reshaped traditional pitch fork with a central square bottom U in it to make a very light weight long handled four round tined fork . They did this for me back in 1982 I still have both fork & the spade. ..... blade is almost 1.5 inches shorter and well rounded at the corners / I lost my rake & hoe when some Richard Cranium just out of jail was given the allotment next door to mine in 1985 , the council cut the weeds down for him and in one of the hottest years for ages he set fire to the tinder dry hay ...... burning my allotment shed ( made entirely of tar pickled railway sleepers ) the rotovator ,the hoe & rake etc inside . as well as burnig a massive 15 x a15 x 7 foot high lasagne style compost heap of layers of veg matter, sawdust & shavings & 7yr old stable muck *& beddings out of the Vets yardRecommendations please for a stainless steel digging fork and spade set please. I'm going to treat myself!
Kent & Stowe come up for around £50 the pair. The ash handles put me off, I think I'd rather composite.
