JMS1972
- NW Leicestershire, UK
I think some of the posh CO2 laser mirrors are polished copper?Copper is a bad material to laser... It reflects a lot of the laser energy which can sometimes damage the laser itself.
Yeah i believe so. So trying to cut or engrave it reflects it back into the lens and/or source. Bigger fibre lasers are supposed to be ok at limited power but i was told by an IPG man "don't cut it on your laser if you have another option"I think some of the posh CO2 laser mirrors are polished copper?
Well they work great for holding a tank whilst removing the valve without damage!Pair of quick and cheap copper soft jaws, 3/4x1/2" bus bar so fitted perfectly.
Would painting it help? An alternative might be to cover it in the photo resist used for PCB manufacture, that'll be a different finish to help prevent reflection and can be stripped away relatively easily. For example we use negative photo resists which can be stripped away with sodium hydroxide (drain cleaner).Yeah i believe so. So trying to cut or engrave it reflects it back into the lens and/or source. Bigger fibre lasers are supposed to be ok at limited power but i was told by an IPG man "don't cut it on your laser if you have another option"
I think it's the puddle of molten metal that's reflective. I was told that's why the ally is harder to laser than steel, because the puddle is more reflective.Would painting it help? An alternative might be to cover it in the photo resist used for PCB manufacture, that'll be a different finish to help prevent reflection and can be stripped away relatively easily. For example we use negative photo resists which can be stripped away with sodium hydroxide (drain cleaner).
Yeah this is my understanding also. I think a coating might help a little tiny bit, but not once it's down inside the cut, and may even have a detrimental effect like millscale on steel does - absorbing energy into itself rather than heating the proper metal.I think it's the puddle of molten metal that's reflective. I was told that's why the ally is harder to laser than steel, because the puddle is more reflective.
Why bother with the wood, just fit the 3d print and call it a day.
the way yours is looking your either going to need a longer stem on your key or you will be hole drilling just to get your key deeper within the door just to get to the lockMaking not made. A lock box to go on an old ledged and braced door. Luckily I've loads of this mahogany cill for when I mess it up! A very lightweight, 3D printed trial lets me know that it'll fit nicely.
Now just to recreate in timber. It will likely involve a jig and router. The lock box is nominally 17mm wide. I do have a 17mm spade bit. That would mean chiselling. All I have is a neglected box of chisels bought years ago from Makro. Rusty and blunt and I'm no good at sharpening them.
i wouldnt do what your going to do i would make it out of steel and then i can use the steel to also strengthen the door as wellIf a serious question then appearance and I'm guessing strength. The old, black painted door (I think oak now from a little test drill) will be sanded where the lock block is going then screwed and foaming PU glued:
I dropped my tree wedge in the stream last week and forgot to pick it up, so £2.40 of amazon door stops ordered and I have modified to make some more. I chopped the ends off and they might make good mini wedges too.
Interesting! For underwater use?The one I lost was one of these. I had to wedge a mini carabiner instead which was a pain.way too expensive to lose.
