The problem with those adjustable sets is that the bar will end up anther 40mm plus off the wall , then you’ll have to pack the riser bar , if it’s rigid pipe off the wall too . Plus it makes for a good weak point being nudged about , and they will start leaking .
The offsets were really meant for being half buried in the wall … so none is seen once the cover plates are on
Sure.With a slim bar and those dog leg things it would still be a massive improvement over the existing one.
I've installed one of those and just got a second to put in. Happy with the units though they are bigger than you may imagine. Had to reposition the temperature know to suit our HW temperature.![]()
Mira Atom EV Rear-Fed Exposed Chrome Thermostatic Mixer Shower - Screwfix
Order online at Screwfix.com. Contemporary thermostatic mixer shower with separate temperature and flow control. Magni-flow technology gives powerful performance and delivers high flow rate, even at low pressure. 110mm showerhead provides large coverage and Coolshield technology ensures the...www.screwfix.com
Looks like it comes with the "z" connectors as standard now, it was an optional extra when I fitted mine 7 years ago.
Check the specs/installation instructions.
-There is iirc some flexibility on mounting width.
-quite large diameter cover plates that will hide a lot of things.
-might look too big in a 700mm shower?
