Its a bed slinger so no, too much mass to moveIs the mini as fast as the x1 carbon?
What's the x1 then?Its a bed slinger so no, too much mass to move
X1 and p1 series are core xy. The bed only moves up and down.What's the x1 then?
What's the x1 then?
Ah I see. I had not looked closely at the complete range.X1 and p1 series are core xy. The bed only moves up and down.
Make a great Shaman's stick headNo idea why son wanted a rams skull but it does look kinda cool , bone coloured PLA and creative use of wood stain
Yea on printables once I've tweaked the assembly required version a bitAre you sharing that anywhere?
Awesome...its one thing i need on the bridgeport.Finally got my quill Dro printed and assembled , took quite a while to design as I didnt want to limit access to anything
uses a standard 150mm vertical readout you can get an m-sure one for £32
M-SURE IP54 Vertical Digital Linear Scale 150mm (6 inch)
M-SURE IP54 Vertical Digital Linear Scale 150mm (6 inch) - A premium Digital Linear Scale designed for exceptional performance and reliability.www.machine-dro.co.uk
its a tight fit but locking screws just in case
still good access to nuts
Holes will need drilling and tapping in the head and quill nut but you could just bend tabs top and bottom in the bracket to stop movement. Could also 3d print one but if you own a bridgeport and cant make one you should sell it !
I can post on Thingiverse if interested
