I sometimes feel like a complete novice at this engineering lark
I need to create some more punches.
I want to do it better than the last time, so wil be using gauge plate rather than mild steel.
I would like to ream the holes to 4mm rather than rely on my 4mm drills, to get a better 'fit' for the punch.
What are the basics of reaming? (No sniggering at the back!)
Is it as simle as I drill a slightly undersize hole, and run through with a 4mm reamer on my drill press?
What size drill do I need for a 4mm reamer please? Or is there better solution using for example slot drills (Are they more accurate?)
first time it happened was a little surprising.
slow and lube. Also don't let it dwell in place , either be pushing it in or pulling it out.
