Hi,
Forgive my ignorance in advance.
Im an old timer but have never used a compressor or air tools. Im in the scrap yard trade (cars). Now i have always used normal tools and grunt to open/dismantle cars. Few of the lads working for me have asked me for a compressor. So i obliged but have a few questions........
I have a compressor and bought some 3/8" id hose. I have a filter regulator with 1/4" inlet/outlet. Now the way i understand it is....
I attach a smaller length 3/8" id hose from the Compressor to the regulator then main air hose runs of the regulator onto my air tools.
My question is, i am led to believe best air hose for air tools is id 3/8". Now what i want to know is if i use a 3/8" hose from the compressor to the regulator with adaptors to go down to 1/4" to fit the regulator and then the same on the other side of the regulator, adaptors from 1/4" to 3/8" will i be suffocating the air supply? Will going down from 3/8" to 1/4" adaptors restric airflow. Its only the adaptors that will be 1/4" to make my air hose fit the regualtor but all the pipes im using will be 3/8 id".
By doing this am i defeating the object of using 3/8" hose by going down to 1/4" for the regulator then back up to 3/8". Will i be suffocating it by going down.
compressor -->3/8" hose--> 1/4" filter regulator-->3/8" hose --> air tools
Am i basically throttling the air supply where im going down to 1/4" using adaptors?
I hope this makes sense.
Any help appreciated.
,in the light of Bright Sparks experience ,may be worth talking to the supplier ask if its ok to check it out,before returning it?
smaller cfm requirements will probably be ok with the thinner pipe but id recomend the larger over longer lenghts .the 3mm jet small pot will run on 14cfm min and best at 28cfm 90psi constant. the larger runs on 90cfm with a 3/4 hose and a 6mm jet at 90psi
