titanic plumb
New Member
- England
Anyone doing it hear?
We have endless supply of the stuff that I would like to burn it safely somehow
I am sure Youtube will be full of ideas
Noooooooooooooooooooooooooooooooooooooooooooooo!
Bob
Bob, how did that casting project work out?
I keep hoping for an update!
so you are saying that some types of steam engine boilers where converted to running on waste engine oilIts quite easy to do.
Many years ago the company I worked at used it in the steam boilers with a special burner and filtration system, it worked very well on old engine oil
full of water was itbut once we started buying it in we had loads of issues as it was usually contaminated.
its full of idiots as well!I am sure Youtube will be full of ideas
But what fuel was the boiler originally desinged for burning?i made a fairly simple one using one of these syphon nozzles (https://www.ebay.co.uk/itm/296162925376?itmmeta=01J1N9068BKZZWEQC7JPH87GMQ&hash=item44f4af9b40:g:HQkAAOSwCvxlomiX&itmprp=enc:AQAJAAAAwK9i1pqhSjmIGQDK5ccIpLR5h06pyJRdXapBVW/qE9xxacNLYOuJeuWNep/9Z8bCkzP9Sjoz1JiGGkf3HFCdStmOKddm0TSdwFWX+IvyQarleI9wrWgJKd+j1DvSl/Dt9Tv2NGPnOCg2J7UZJIaMfBretXL6/+UQ9GOw9JGN0/luyXXWTxZnaAfrnZGlSnSUoO7T2IpXjAORMwiRe6NIp58jWyAPfIgh1oSqvqXA4Ge+TDk/eF8ZbDFmuB2txFgsYw==|tkp:Bk9SR6LkgKmNZA)
fitted in the housing of an old riello burner, actually works very well, no visible smoke, no smell at all, and lights very easily with a blow torch. doesnt use that much air from the compressor, i only have it on 10-15psi
do you know if you can buy one of those ready made?The mock up burner
garage owner i presumeAnyone doing it hear?
having read your OP from the link; it loos quite complecated! as i dont even know what most of the part areYou can buy some of the jets and igniters on ebay, the rest is a mishmash of bits I had here, bit more on it here https://www.mig-welding.co.uk/forum/threads/waste-oil-smelter-build.115355/
Bob
What was its max power out put?I used a Kroll waste oil burner to heat my workshop and bodyshop, ducted hot air, the burner used compressed air, it did grow a ball of clinker in the tube just in front of the burner unit and we had to pull the burner unit out and remove the clinker every two weeks or so, the oil was filtered and the small oil tank was heated, we also had a small tank of heating oil in the workshop, the waste oil tank was out of sight, there was a switch over valve, it burnt very cleanly, no soot or smoke except at first start up or if the clinker ball was getting to big! warmest workshop in Enfield......
