Blobber
- lincolnshire
We haven't had anything to miss yet!It was three days ago. Did you miss it?
My one was missing the divider like yours and I made one. The original was spring loaded with a torsion bar inside. The replacement uses a long tension spring so it can move if it hits something solid. Let me know if you need photos if they are on my haybob post. I don't know if it is needed or not as the previous owner didn't need it and they seem to be missing or broken fairly often.Last little bit on the Haybob before we can use it in anger or be be angry as we cant use because of the weather!!! anyhow the headstock stand had been proper farmered
even the tube it slides up and down in was out of shape
Ive no heat so ive either got take the headstock off to find something hard to smash it about on or improvise
with that sorted I dug out a bit of galv malleable iron pipe the perfect size, not very strong but if it does bend it will be a gentle bend!
recycled the foot plate with a nice hot weld, ran away after welding to let the fumes dissipate!
Ooooh fire in the hold!!!!!!!!
recycled one of the old tines into a locating pin
jobs a goodun, not sure why its at a jaunty angle, I guess something else is probably bent/twisted
On my 73 750 highrider when I bought it in 74 it would kick the hell out of me when starting the mechanic had no idea seeing as how the timing checked out. Looking at it myself I found the auto advance unit was worn to the point it would never be in the same spot twice causing the backfire/kickback.Managed to get back onto the Norton Dominator today.
It's had a fair bit of work done to the engine apparently, 750cc.
I broke my heel years ago and normally only gives me a bit of jip in winter but this bike is a bloomin beast to kickstart and feeling it tonight!.
If anyone got any leads for a longer kickstart I'd be interested to know as the owner's had similar issues trying to kick it off (to be fair it never ran for more than a few seconds).
If you own a ford that Forscan is worth its weight in gold...just bought a laptop with a full license installed for my MK6 trannieNipped it in the bud, DPF_LOAD was 141% and DPF_SOOT_LD was 127% before driving.
Fitted the Vapouriser and couldn't clear the Regen Codes straight off, went for a drive and it's sorted itself out. Cleared the code and another drive and it's a clean sheet (we have an aftermarket head unit after Sync1 failed).
I didn't thrash it, just drove normally and the car burnt all a the soot out. Probably half an hour total driving.
Luckily my wife knows when it's doing a regen (fans on, instant consumption 0.5 gph, light tapping under floor) and she mentioned it was doing more than usual so that's saved it really.
A beer and a Pizza now!.
If you own a ford that Forscan is worth its weight in gold...just bought a laptop with a full license installed for my MK trannie![]()
Unfused lighting used to not be uncommon.
The argument was it was too expensive/impractical to fuse individual lights, and if you used a single fuse, then a relatively minor fault could lead to suddenly being plunged into complete darkness, which isn't the kind of thing you really want at road going speeds.
Probably an EU directive...I suppose a wiring loom fire and loss of engine is better than losing the headlight. Must be a German thing.
I know you're being snarky, but you'll probably find current EU legislation covers circuit protection, it's just most things are grandfathered until a complete redesign is done, or full type approval is required.Probably an EU directive...
I hate painting!Today I 'fixed' our backdoor (mostly just paint).
The paint looked pretty rough with lots of chips and this morning I just could not stand it anymore.
I used a primer I won on an auction recently. Don't know much about it.
Next was the top coat, again paint from the auction.
Nisocoat 2, seems decent
The usual suicide bugs
Now rapidly trying to get the paint dry enough so I can get the door closed!
I don't mind the painting so much. It is all the prep and cleanup I hate!I hate painting!
