Every inch of the wall space inside is used, I’d still have to lose the width of the door even if it opened outwards.The access door could open outwards
Sound like you might benefit from a shed at bottom of gardenEvery inch of the wall space inside is used, I’d still have to lose the width of the door even if it opened outwards.
Line the inside with 12mm plywood or OSB, give it some rigidityThis is the kind of thing I had in mind, just not sure how it’d go with it being fibreglass. And once it’s cut there’s no coming back.
These would be the perfect solution.you mean the access door or also known as the man door within a door
View attachment 453019View attachment 453020
We already doSound like you might benefit from a shed at bottom of garden![]()
 2 small ones, That’s where the pushbike/kids/garden toys live though, and then there’s another with all the garden tools etc live. As understanding as the other half is if a workshop shed turned up as well that might just be the straw that broke the camels back.I don't understand this - when you open the man access door you appear to walk into 2 horizontal stiffeners (?) plus the bars of the locking mechanism.to give you an idea of access with that door you have
View attachment 453021View attachment 453022
i can fit a door and seal it to what you have just by using whats available off the shelf
Look closer.I don't understand this - when you open the man access door you appear to walk into 2 horizontal stiffeners (?) plus the bars of the locking mechanism.
I don't see it - anybody else?![]()
the middle lock uses a twist cam to open the door with adjustments you can refit more twist cams to still open the door at the middleI don't understand this - when you open the man access door you appear to walk into 2 horizontal stiffeners (?) plus the bars of the locking mechanism.
I like this idea and think it might be the route I go down.to give you an idea of access with that door you have
That's a double skinned Hormann garage door... good luck insetting a man access door into that.to give you an idea of access with that door you have
I’ll never have one of those for my garage, #1) I can’t park in the 2car garage, #2) I always enter from the front and might use the alleyway behind the house once or twice a year except for putting the garbage in the recycle bins.Nice door. I'd simply fit a power opener![]()
Yes you can become a Limbo Champ!I don't understand this - when you open the man access door you appear to walk into 2 horizontal stiffeners (?) plus the bars of the locking mechanism.
