oldbikedavey
 - London, England
Sounds like a Walker mower. Used to use those in France, and the air blower is a very good thing to have, as it tries quite hard to keep the dust and straw chaff localised and directed from the rear of the machine, besides compacting it quite well in the rear box.My mower has a frontal deck that side exits so it sprays grass out off to one side rather than rotary cylinders as they're a bit better suited to uneven surfaces. You can get batwing mowers the same for gang setups. I just blow the rad out when I fill the tank and check hydraulic levels. The air filter the same which does get dirty quickly otherwise.
When I bought it , it had a grass collection system with a extra fan that attached the deck exit and fired the grass into a big container on the back, which was hydraulically tipped out periodically.
But, I dont want to spend my life making piles of grass clippings, and removing it helped stability on banks which I need.
I noticed your machine is a cylinder mower, hopefully your paddock is flat and not riddled with molehills and surprise holes left by the dogs.
