steveo3002
whizz over the scabs with a clean n strip disc then on with the blaster or rust gel
yep so cleaner will be better , keep going till no brown pits then primer without it sitting about in the damp
Have you had any long term success with rust converters then? I gave up on them years ago after finding they all seemed to fail after a very short period.I quite like the 1 pack epoxy rust converters for undersides...2 part epoxy primer is great if you can prep properly (ie blast) but with my imperfect prep when I've used it the adhesion hasn't been great!
...looks like you just want to touch up a couple areas and stop the rust progressing any further?
Yeah, I really don't like that ****ty black coating, but it was put on when the van was almost new rather than more recently to hide existing rust, the only issues I've seen after extensive checking over are areas where the surface has been damaged by careless jacking, the wheels rubbing and some minor impact damage, so once those areas are rectified, it'll get a clear wax coating over the underside and regular inspection for any new issues. No winter use and proper garaging should see it outlast me hopefully lol!Spotblasting will be perfect for those rusty spots and then a couple of coats of epoxy primer by brush before applying whatever top coat you want.
The below was done on the inner guard of a very rusty Alfa and didn't take that long.
The trick is get it close by whatever method you can (grinding, wire brush, sanding etc) and then give it a final going over with the spot blaster which gives you an ideal surface for primer.
I'd be surprised if there aren't other problems lurking beneath the rubber seal, but if you keep on top of it you should be ok.
All you can do is repair any issues as best you can (so you don't have to do them again) and deal with the next issue as soon as it arises.
Hmm, I've not come across those, will give them a try, where do I find them?whizz over the scabs with a clean n strip disc then on with the blaster or rust gel
I use the 1 pack aerosol converters...I'm pretty happy with them. I feel like it adds a layer of protection just in case the top coat fails.you had any long term success with rust converters then?
Yeah, I've been working over the under arch areas again today, decided to just use my 81% phosphoric neat this time, soaked a sponge in some and dabbed it on over the area, gave it 5 mins, dabbed more on, then worked over the pitting with scotchbrite pad and a small fine hand wire brush. After a couple of sessions of this, all the pitting rust is out and it's all bright silver and utterly rust free. Wiped everything off whilst still wet, followed by a final light wipe on/off with very dilute phosphoric acid and let it dry for 1/2 an hour.Rust converters would be pointless for the issues on this camper, using a proper acid the rust can be totally removed without too much bother and the repair will then be as good as new rather than sticking plaster.
I've found citric to work better than phosphoric on stuff like that, the trick is to keep it warm. I used kitchen roll pieces soaked in citric solution and kept wet with a hand sprayer they stick in place. Warmth achieved by a halogen floodlight pointing at the area.
If you were using Lechler you would be limited to citric as phosphoric will affect the zinc phosphate in the epoxy.
The rustbuster epoxy mastic you have is ideal for these repairs, it's a bit thicker than the Lechler and is designed to be brushed on.
Question now is, do I leave the phosphated surface as it is for protection and paint over that?, or abrade first, removing it, prior to painting?
sounds more like it , where did you get the acid , sounds like i ought to own someYeah, I've been working over the under arch areas again today, decided to just use my 81% phosphoric neat this time, soaked a sponge in some and dabbed it on over the area, gave it 5 mins, dabbed more on, then worked over the pitting with scotchbrite pad and a small fine hand wire brush. After a couple of sessions of this, all the pitting rust is out and it's all bright silver and utterly rust free. Wiped everything off whilst still wet, followed by a final light wipe on/off with very dilute phosphoric acid and let it dry for 1/2 an hour.
Yes, just for more money.is this what jenolite is /was?
Thanks for this. Interesting recommendation.I find that using phosphoric acid at high strength is counter productive, it is quite oily at high strength and is not as effective as you would expect. I used 30% for rust removal and 12% for the wash. Wipe very dry using clean paper wipes, allow to flash off the last of the moisture and scuff up ready for paint.
I find that after a 12% wash bare steel can sit for weeks without flash rust. I really should do a test piece to see how long it will last.Thanks for this. Interesting recommendation.
I have been looking at options for an upcoming resto that has a lot of surface rust and im always trying to improve my methods. Would a 12% phos wash still be enough to compromise the adhesion of the lechlar epoxy do you think? I want to find a way to stop the flash rust after surface prep and a weak phos wash may be perfect for that.
