and the blue thing is the heat exchanger
Dont think I have ever seen that many strainers used on an installation, whats being pumped through it?
Bob
No mug or banana for scale
Nice.
We skid mount a lot of our gear. Means it can be built in the workshop, dropped in place and just the interconnecting pipework and services to sort on site.
If you ever strip one of those heat exchangers, pay close attention to the order the plates go in, and measure the conpressed length before you undo the clamp screws.![]()
Does it’d supply a hospital with fresh/re circulating water?
Good advice…hateful things…..those butter fly valves pass in about 15 minutes of use too.Nice.
So is this heating, using low pressure steam on the primary and inhibited water secondary.It's all hospital stuff so will be part of the spec. It's secondary side so will be water with inhibitors. Central plant for a de-steamed system
Not having that, the lid is 2 3rds down the length which make it a stubby wheelie bin, not a standard gauge block wheelie bin, banana or mugYou have made a valuable extension to the forum's standard method of measurement with "wheelie bin for scale".
Secreted in the vorpal tunnelWhere's the flux capacitor?
Ah ok….maybe more decarbonised on paper, but seems to be far more complex than a simple steam plant..
Steam high energy I agree, not the most efficient process. But your new system has 4 heat sources needing maintenance. Dangerous is relative, not convinced Id put low pressure wet steam in a dangerous category, but suppose it depends what folk are used too.Steam not good, high energy, high maintenance and is really quite dangerous
Most hospitals will be de-steamed at some point
