Here's mine. Well used and abused...View attachment 447870
 Just got to get an MOT on it as its road registered, a couple of lights need attention plus the horn, everything else works ok and brakes seem good. As most of these things are CVT (Mule, JD Gator, Honda Pioneer etc.) if you idle going down a hill, the belt disengages and it free wheels so lose any engine braking. So you stick it in low box and give it just enough revs to not slip out of gear, or just go down on brakes....... We shall see, my neighbour has one and is fine so probably not an issue once you've done it.
 Just got to get an MOT on it as its road registered, a couple of lights need attention plus the horn, everything else works ok and brakes seem good. As most of these things are CVT (Mule, JD Gator, Honda Pioneer etc.) if you idle going down a hill, the belt disengages and it free wheels so lose any engine braking. So you stick it in low box and give it just enough revs to not slip out of gear, or just go down on brakes....... We shall see, my neighbour has one and is fine so probably not an issue once you've done it.it should be in the Poo sticks thread??Local council uses one for dog bin rounds in the park.
I have and still use that tester, cracking bit of kit.
I was looking for months and months for a Fluke 1587 or at least 1507 ,cheap ones I've had no money for, other ones got so high of a price I wouldn't even imagine to buy them.
I have a 1552 it is 20 years old and passes it's calibration every year with no problems ever, absolutely bulletproof tester!!I have and still use that tester, cracking bit of kit.
Does it need an MOT? Surely it's an agricultural vehicle?Kawasaki mule 4010 diesel, 2013. Ex-council road cleaning dept. so probably been serviced occasionally, quite high mileage/hours but probably not had a hard life. I like the cage on the back, also got a heater so its the luxury versionJust got to get an MOT on it as its road registered, a couple of lights need attention plus the horn, everything else works ok and brakes seem good. As most of these things are CVT (Mule, JD Gator, Honda Pioneer etc.) if you idle going down a hill, the belt disengages and it free wheels so lose any engine braking. So you stick it in low box and give it just enough revs to not slip out of gear, or just go down on brakes....... We shall see, my neighbour has one and is fine so probably not an issue once you've done it.
I've heard the same about Fluke test kit.Thought about an installation tester from fluke (used obviously) but they seem to be very depressed and if you don't use them often they feel lonely and commit suicide.
I went off Fluke test gear years ago due to glitches/ faults in fact I bought my first Megger as a result of inconsistent readings from the fluke MFT I had.I've heard the same about Fluke test kit.
I have a fluke thermal image camera that cost over £700 and it's appalling. Slow, glitches, and the software is joke,
Oh they definitely are that, especially the 1552. Mine has been dropped, soaked, frozen and cooked. Used on farm installations for 16 years until I retired it for the 1741+.I found the Megger MFT's almost bomb proof.
 my thoughts though   probably pinched  not working correctly and out of date
 my thoughts though   probably pinched  not working correctly and out of dateI have a Fluke 115 and love it, an ACDC clamp meter I didn't used enough but overall good, and a laser thermometer I think 62 Max.I've heard the same about Fluke test kit.
I've got a 1507 great bit of kit. Would like a 1587.I was looking for months and months for a Fluke 1587 or at least 1507 ,cheap ones I've had no money for, other ones got so high of a price I wouldn't even imagine to buy them.
I was thinking also about UNI-T brand new cause personally need an insulation tester.
Lost a Megger br11 5KV insulation tester, later found only pat testers I don't need.
Don't know why theese randomly fail and cannot even be repaired.
So I found this one as spare and repairs for the broken knob and the battery pack both not a big of a deal so I've bought it
IR thermometers aren't very accurate because they don't know the emissivity of the surface they're pointed at. On the 62 Max you can set it, it's probably around 0.98 which is good enough for most things but a polished steel surface for example might be scolding hot but the gun reads it at room temperature.a laser thermometer I think 62 Max.
This is kinda strange but I don't know if it's because of the meter itself or the technology used, but values are not as precise as I thought would be.
Never found it to be very far off when checked with a k type thermocouple, even on fairly reflective steel surfacesIR thermometers aren't very accurate because they don't know the emissivity of the surface they're pointed at. On the 62 Max you can set it, it's probably around 0.98 which is good enough for most things but a polished steel surface for example might be scolding hot but the gun reads it at room temperature.
