By sparkies or those who wrote the regs at the time and sparkies complied without fully understanding them?it was called the silly seasonif u had a metal curtain or hand rail they wanted it bonding
no and im not going to it will be a pig to stripHave any of you sparks tried the new CPC sleeved T&E yet?
havent got all day to strip stacks of cableI haven't tried it yet as I still have about 150m of earth sleeve in stock.Have any of you sparks tried the new CPC sleeved T&E yet?
What?! efix did a gaztube on it and it didn't look that bad at all, I'm quite looking forward to it, no more sleeve falling off!no and im not going to it will be a pig to striphavent got all day to strip stacks of cable
the not much cop in socket and switch boxes removing the outer core right back to the grommet . only any good on loose cables just use side cuttersI already use mechanical cable strippers, I find myself going for them more and more over side cutters or a knife!
I think it was the 15th as that's what I came out my time with and I remember bonding radiators and Crittle window frames.There was an edition of the wiring regs, can’t remember if it was 15th or early 16th when people went mental with the supplementary bonding and basically anything metal they could lay their hands on ended up with a green and yellow cable clamped to it regardless.
Radiators, worktops, window frames, the cutlery in the drawers.
I have never owned this tool and it to would be fair to say I'm a bit of a tool geeky or at least like to be able to buy more if I could.I use these,
C.K T1260 Automatic Cable & Wire Stripper
In stock C.K T1260 Automatic Cable & Wire Stripper. 1-year manufacturer warranty. Next-day delivery is availabletoolshouse.co.uk
I can get to within the depth of the jaw in most cases, about 10mm, that's close enough for most outlets these days with 35mm boxes for most outlets.
I really rate them, I am a convert from a good old cable knife, that's how I was shown as an apprentice. Never moved to the yank the cpc crew,
These I have had a fair while now, still sharp and effortless on T&E, flex, data, even HO5-7 up to about 1.0mm 3core.
It's fair to say I'm a convert!!
i use the ck strippers on wiring recessed lights with loose cables only 1.0mm cable there fast and ideal. handy for making flex of as well but thats about allThey are an excellent tool, I didn't pay that much for them, I got them from the ELEX show at Coventry, think they were around £39 ish.
I tried them out and was converted!
I have a set of these too,
C.K Automatic Wire Stripper
Save time while working on electrical tasks using the C.K Automatic Wire Stripper. This versatile product is suitable for stripping both flat and round cables and wires. All it takes is two clicks to remove the outer sheath, as well as extracting the inner conductors in a cable.The tool is...www.toolstation.com
But don't rate them compared to the newer type ones! Still a good tool just no where near as good!
Sy
There are loads of people selling them, even wago have started selling them.I thought the quickwire ones were supposed to be the dogs danglies. CK also do a rebrand of them IIRC
Pricey little beggers though.
