Shedendman
A young lad bought the vice,he was only 17 at the time,was right into being a blacksmith,i felt so proud that a kid of his age was keeping the ole ways alivelooks well good both of them![]()
In hindsight, I would have made my vice stands (blacksmith vice stand, foot vice stand) with fold-up foot plates, since even a 1/2" steel plate presents a bit of a tripping hazard. I don't think I'll change them to fold-up at this point, although I might grind a shallow bevel on the edges, which should reduce the tripping hazard.You might want to include a small platform to stand on. If that is firmly connected to the legs, the vice cannot possibly move when you push and pull on anything. I made one that folds up the only slight issue being you really want a thin sheet of something to stand on or it becomes a trip hazard.
I have used Zinga brand of galvanising paint. It has a high zinc content and I`m pleased with it after using it on my trailerCool, I was thinking of the cold galvanising paint, I also have a blacksmiths leg vice….
I like this and it makes perfect sense, but the whole thing is begining to get complicatedYou might want to include a small platform to stand on. If that is firmly connected to the legs, the vice cannot possibly move when you push and pull on anything. I made one that folds up the only slight issue being you really want a thin sheet of something to stand on or it becomes a trip hazard.
This is the vice I have, minus the swivel base
That a neat little contraptionVice is removable just nocks into tapered stake holder other tooling can drop onto the stand.View attachment 446814View attachment 446815View attachment 446816
I will drill holes through the round section, but I will loose the swivel option, that’s not an issueView attachment 446789
How are you going to secure the vice body to the stand, without those mounting holes?
I’ve no idea about price@Parm
I may have a stand that you could become the owner of. It's a Woden brand, three-legged stand.
I just need to convince myself that I can part with it, since it currently sits in the garden with an arbor press on it. Also, what would be a reasonable price![]()
What does the underside of your vice look like? Could you use or adapt the pivot bolt (or rod or threaded hole) somehow for mounting the vice to a stand? A pin could be added to prevent it from rotating. That might allow you to mount the vice without doing anything invasive to the vice.I will drill holes through the round section, but I will loose the swivel option, that’s not an issue
The threaded section has snapped off, will post up a picture later onWhat does the underside of your vice look like? Could you use or adapt the pivot bolt (or rod or threaded hole) somehow for mounting the vice to a stand? A pin could be added to prevent it from rotating. That might allow you to mount the vice without doing anything invasive to the vice.
Now I have to build a press…..What about an option for those who have a solid hydraulic press?
Just bolt vice to a substantial plate and grab it with the press over hanging the bridge? Will give a good working clearance all round and as press is occasional use it can be removed when needed.
